Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 80
Thread: rig truck help
  1. #31
    arkansas
    781
    got the bed completely tore off about three days ago, and went and picked up steel to make another flatbed frame for it.
    welder_one
    www.sicfabrications.com
  2. #32
    arkansas
    781
    i used this stuff called metalize. its a rust converter and changes rust into a primered surface that can be painted. i used it on steel structures around swimming pools before. neat stuff. i laid out the frame for the flatbed last night and welded it together. i used 1 1/2 x 1 1/2 square tube 3/16 wall for the frame runners that follow the truck frame. the rest is 1 1/2 square tubing 11 guage, except for the sides. there, i used 2x2 1/4 angle. i did that so that i can use tie downs and straps easily. the last one is hard to see. it was late. i used .080 aluminum plate to mount the lights.
    welder_one
  3. #33
    arkansas
    781
    this morning , i picked up some lumber and carriage bolts. they are 2x6. the bolts i used are 4 inch 316 stainless at 5/16 diameter.
    I HATE DRILLING HOLES!!!!!!!!!!!!!!
    lol.........100 bolts to be exact.
    welder_one
  4. #34
    arkansas
    781
    i built a headache rack for it today and pulled new wires for the brake lights. i will post pics of the rack later.
    does anyone know anything about quadrajunks? the truck has a bad stutter when under full throttle. any other throttle position, it does real well. i dont know enough about them to try and adjust it, also the secondaries arent opening (probably the stutter) and i cant figure out how to get them freed up. they will open by hand but not by throttle linkage
    welder_one
  5. #35
    May 2007
    729
    If you have a Rochester Quadra Jet w/ vacuum secondaries, it NOT going to open with the throttle linkage. If it stumbles or bogs as soon as you floor it, your accelerator pump may not be functioning properly. It may have nothing to do with the secondaries, but a momentary lean condition until the main fuel bleed circuit catches up. Time to pull the top off, clean it up & maybe throw in a rebuild kit while you're at it.
    Sorry to suggest more work.
    Later,
  6. #36
    arkansas
    781
    work is something that i am not afraid of, especially more of it. i have never been into a rochester, black wolf, may i pm you if i have more ?'s about it
    welder_one
  7. #37
    arkansas
    781
    here are pics of the headache rack
    welder_one
  8. #38
    looks more like a backack rack to me. you head is still above it.
  9. #39
    May 2007
    729
    By all means PM away. No need to ask but the gesture of respect is appreciated. Always glad to help out.
    Later,
    Jason
  10. #40
    Vero Beach, fl.
    761
    Default Carb advice
    The best advice I could give you on the Quadrajet is take it off and put yourself on a Holley 4412 and an adapter plate. Qj's are good if you get them dialed in right but a real nightmare if you don't know much about them. The Holley 4412 on the other hand is a great 500 c.f.m. 2bbl. carburetor, it'll save you some money on gas and is very simple to repair if needed. Dave
