Page 1 of 8 123456 ... LastLast
Results 1 to 10 of 80
Thread: rig truck help
    arkansas
    781
    Default rig truck help
    i am looking at a 1946 gmc coe truck. i would like to modernize it with new model duramax diesel and allison transmission. anybody have any pointers for this?
    welder_one
    www.sicfabrications.com
    i have a 51GMC i considered just pulling the frame out from under t and replacing the hole bottom 1/2 with new frame engine and trany. make a few alterations as needed to get the shell back on and call it done.
    might be an option ?? or are you looking to keep the frame and just drop in a new motor?? as i understand it you have to move the steering box outside the frame causing a shorter turning radius to one side. that is you just drop in a V8 although many cut the front of the frame out and replace it with the hole front of another one. mustang 5.0's being a popular choice.
    be shore to give us lots of pic's.
    arkansas
    781
    i ahve not ever dealt with the restoration of an older vehicle. it was a thought that i have to pull up to a job with an old gmc, but with diesel power to have the power. you know... it is an idea to use the body on another new truck frame. i don't know, i havent even bought it, just dreaming mostly...
    welder_one
    i have had mine for about 12-15 years now. nice truck, i love the side cab corner windows. i saw one similar to mine with a tool box bed like the phone company uses and it looked sweet. thought about going that wrought seeing as some one rear ended me a wile back and trashed my bed. its a few $1,000 to replace the hole bed. but all the steel is available ready to install.
    i was just thinking a cab swoop would be the easiest way to get all the electronics needed with a newer motor. not to mention a new suspension and steering setup would be nice. i do have the original steering wheel in it so its huge and helps with turning but for a cruse around truck i think i would like to go to automatic and power steering. figure if i get a newer donor truck i can possible do a little modification to the power windows and get that set up in my old door's. all the extra parts would come in handy no question about it. i also have a bad spindle on one of the front wheels where the bearings blew out on me and it eat up part of the spindle in the middle. doesn't effect the fit as the bad part is centered but its just one of them things that needs fixing. my front leaf spring is also got a crack in it and part of the mount is in bad shape. its all fixable just a question of how i want to do it ??
    its my first real restoration too. all i did to mine when i got it was get it running and start using it as a work truck. now that i am retired i figure it deserve to be retired too, only in better shape than me.
    Ocean City, Maryland
    951
    Thumbs up
    Quote Originally Posted by welder_one View Post
    Cool old project. That would be cool to put a new "modern" diesel and trans in an old truck. but...one problem......Both the duramax and the allison are computer controlled. There is a considerable amount of wiring, harness's, PCMs, etc . Not to mention sensors, relays, electric fuel pump and so on, envolved with todays diesels not to mention the cost. An old carburated gas engine or old diesel would probably suffice at way less cost an headache. They do make after market fuel injection kits for older gas engines that from what i hear work well. Unless you could find a totalled truck and use all the wiring and all from it. My opinion would is the project would be cost prohibitive Of course if you have the money and time I would love to see it completed, it would be very cool.
    Scott
    HMW [Heavy Metal welding]
    arkansas
    781
    hmw, it would be cool, but you are right, the cost would overcome me quickly. especially if you asked my wife...lol. i wonder if there is a way to get an older...say john deere or cat diesel to mount to a more modern tranny(would rather a stick anyways) and work it that way. i am grabbing for straws here...
    welder_one
    Dec 2005
    Lodi, CA
    1,495
    Back in the early 80's, when I was living in San Luis Obispo, there was a guy, had a '46 Mack, with a late model (for that time) Detroit Diesel and appropriate transmission for it (this was hill country). Very cherry rig, he did mostly SS tig work, don't remember what machine he had on the back. Very simple doing the physical retrofit, done it many times myself, especially with forklifts, strip the frame, drop the engine/transmission in, build mounts and driveshaft to fit. Like was said before, better to stay away from newer electronic setups, unless you have previous experience and knowledge.
    Jul 2007
    28
    It can be done, but how deep are your pockets for this ??? You will probablly have to up the rear end as well. Thus a double check on chassis width for the new axle. Full time your looking at 18-30 months if your not a full time mechanic liscensed for the Dmax. I would look at The diesel page.com for some minor technical info on the DMAX. Get an issue of Diesel Power and search some links. This months issue has some nice retro fits with the Dmax,cummins, and powerjoke. Shouldn't be hard to find a good used D&A combo with under 50K and for under 12K. Maybe even under 10K, have heard of some good finds. An easier project would be the Cummins with common rail injection.( milage-power and a true million mile motor) The allison would need a custom program tho.
    Jun 2007
    Camden, SC
    156
    Default Thanks For The Link
    Quote Originally Posted by PLUMMER View Post
    I'm staying out of this conversation for the most part, but thanks for the link...it should help me with a project I've got planned.
    ~Clint
    Clint Baxley
    Baxley Welding Service
    Rembert, SC 29128
    951
    Thumbs up
    How big is this truck. Ive not heard of that model before. Is this a pickup sized truck or larger, medium duty truck. Either way. We have no cummins but lots of Cats, Powerstrokes, and duramaxs. I know that all newer Cats, Duramaxs and Power strokes are computer controlled, I would assume the cummins is to unless you can find an older one. I hear they are great engines. As far as common fuel rails I'm not sure why that would be an issue, Plummer would have to explain a little more why thats better. t would seem there are bigger obstacles than that. All the new diesel engines are similar and share a common fuel rail or galley. The Fords have a common fuel rail in the head and Hi pressure oil galley in the head, the duramaxs have a common oil galley in the heads with an external common fuel rail. The Cats have both fuel and oil galleys in the heads. Again not sure about the cummins. All the diesels actually have oil fired injectors, In other words hi pressure oil is used to acuate the fuel injector, unlike the old days when you had "piston" type injector pumps.
    Plummer thanks for the web site.
    I still would serously consder gas engine, theres also the weight issue if not a larger truck.
    Sorry for rambling, hope this helps some
    If any one has any questions on diesels or gas engines, I have worked on them for 25+yrs and have tons of resources. I'd help if I can.
    Good luck with the project, let us know what you decide
    Scott
