Results 1 to 8 of 8
    PA
    286
    Default Home made weld positioner
    Here is a weld positioner I came up with after getting frustrated
    trying to get the pieces in the right position for welding.
    It is made from 1 inch thick stainless and has 2 pivot points at 90
    degrees apart so the part can be angled to the right position.
    The part holder is able to rotate 360 degrees to make all sides
    accessable.
    I used 1" sch 40 pipe for the clamp and got a cam clamp from Reid
    Tool to make the clamping action a lot quicker.
    The part holder is made from a piece of 3/4" sch 40 pipe which
    makes it easy to make extra tooling.
    The sculpture is 12" in diameter and is made from stainless spoons.
    It has a 1/2-13 nut welded inside to connect to the matching stud
    in the tool holder.
    Jan 2009
    Cleveland, TN
    229
    that's pretty slick.
    Dynasty 200 DX runner
    Sync 350 LX
    XMT 300 w/D74 and roughnecks
    Hobart 135
    ESAB PowerCut 875 plasma
    Sep 2008
    Omaha, NE
    447
    That's really pretty clever! Reminds me of my "helping hands" soldering and model building thingy I got from harbor freight. I may have to build one similar to what you've made to help me on some projects
    Nice work!
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
    Island Falls Maine
    562
    Looks like it works for you.
    looks good, yo should get lots of use out of it.
    now for us artsy fartsy type, lets see some pic's of the spoons.
    PA
    286
    ok - here is a 20" diameter sculpture made from spoons.
    Used up a 336 cu ft tank of argon to do the welds.
    Tigged it at 25 amps DC using .035" 308ss wire.
    It has a 1/2-13 stainless nut welded inside to hold it to the stand. Makes it easier to take apart for moving.
    After seeing this, my friends now say they will get a metal detector to check me after they serve dinner. I guess it's better than making me eat with my hands.
    Raymore Missouri
    1,906
    Spoon Ball........a new sport...............Looks good. Nice lawn or house art.
    Does it have a motor? Gee I hope so. It would be great to have it spin slowly is the sunlight...................Good job man....................
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Thumbs up
    looks great.
    i was going to ask where you get all the spoons, but looks like you already answered that question.
    my friends now say they will get a metal detector to check me after they serve dinner. I guess it's better than making me eat with my hands............
