Results 1 to 7 of 7
    Dec 2008
    Arizona
    812
    Question Plasma Circle Cutter
    I was going to fab up a circle cutter attachment for my 375 and had a question. I noticed that the straight cutter guide that I purchased is made of a plastic material, is that because a material that conducts electricity would cause a problem when attached to the cutter head on the torch? Or would it be OK to make one out of aluminum or brass?
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Sep 2008
    Estevan, Sask
    111
    I`ve made a couple out of steel with no problems at all. Some plasma cutters don`t like metal touching the side of the tip which may be why the guide you saw was made from a type of plastic.
    Nov 2008
    Kansas City Metro
    387
    I havent had any troubles from my 375 x treame. My circle cutter is all metal and is basically an o ring the cutter guide and another o ring to hold it all to the outside of the retaining cup. I am still using the factory supplied cup so I believe that it is non shielded.
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    Dec 2008
    Arizona
    812
    Thanks, I'' proceed with my plans!
    130XP MIG
    Spectrum 375
    Jul 2008
    Appleton, WI
    30
    Default Circle cutting guide
    In general as long as your guide uses the retaining cup you are good to go. The cup (unlike the tip) is not a conductive part of the cutting circuit.
    Hope this helps,
    Brian Brown
    Service Technician
    Miller Electric Mfg. Co.
    Nov 2008
    Kansas City Metro
    387
    Here is a pic of mine. Not sure if it will help or not, I just thought I would post it incase someone wanted to use part of the idea.
    Jan 2008
    In wal-mart
    460
    Quote Originally Posted by tom37 View Post
    Necessity, the mother of all invention!, nifty rig their tom.
    If you want peace, be prepared for war!
