Results 11 to 20 of 30
    torch? i meant good working foot/finger control.
    Dec 2008
    152
    Releco relays and others have a test button that manually closes 2 poles in the relay. Is this a switch?
    No, it is a relay
    A micro switch is never referred to as a relay nor is a torch trigger over here.
    So a voltage switch is referred to as a relay by you guys over there?
    Sep 2008
    Charlotte Court House, VA
    105
    Quote Originally Posted by Jake SS View Post
    No, it is a relay
    Not really. A relay is sometimes referred to as a "electro-mechanical switch" but I've never heard of a switch being referred to as a relay and I've been design and building control systems and automation equipment for about 37 years, not that I couldn't have missed something.
  4. #14
    Aug 2006
    Raymore Missouri
    1,920
    It is a micro switch and not a relay. A switch needs physical force to activate it. A relay has contacts like a switch but also a actuator such as an electrical solenoid to activate the switch and can be controlled remotely.
    Now put a solenoid on your switch and you have a relay.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  5. #15
    Oct 2004
    Edmonton, Alberta
    8,174
    No, it is a relay
    Nope the electrical portion of the Releco is a relay, the mechanical test push button is a switch.
    Same as a positioner table hitting an magnetic switch and reversing itself, no physical force really, just a polarity pickup, or even an electric eye picks up a discrepancy in its field of vision, or encoders that is also a switch for wave form production.
    An IGBT is a ultra fast switch, as are transistors, mosfets, scrs and such, all electrical switches.
    Its all the way you look at the problem to get the job done.
  6. #16
    Jul 2008
    Delhi, Ontario:
    1,990
    Question Location ???
    No, it is a relay
    Jake, Where are you from, You Do Not Say where you are Located ?
    .............. Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
  7. #17
    Dec 2008
    152
    Nope it is a relay, that is it's main function. Some relays have a mechanical actuator, "flag", led's whatever but for all intents and purposes they are still a relay with a coil and some contacts.
    IGBT's, fet's, micro's are indeed switches, they are not relays
    My main point is why do you guys refer to a micro switch or a trigger switch as relays?? This is the third time I have asked the question and all I get is a question in response to a question.
    Just curious as to why?
  8. #18
    Dec 2008
    152
    Quote Originally Posted by GerryR View Post
    Did you read my posts thats what I am asking, why would someone call a switch a relay ?
  9. #19
    Sep 2008
    105
    Because they don't know any better??
  10. #20
    Oct 2004
    Edmonton, Alberta
    8,174
    I come from an aircraft background, circuit diagrams don't differentiate between a micro switch and a electromecanical relay. I know what thay are on a circuit diagram and that is all that matters. We were only talking about a foot pedal, where the OP was calling this device a limit switch.
    I called it a relay as 2 pins in the pedal close to tell the machine to start up.
    For me its symantics, I was trying to make it simple for the guy to understand
    Yes this is a mico switch even made by Mico switch
Tags for this Thread
