Results 11 to 14 of 14
    Nov 2005
    Buhl, Idaho
    53
    Quote Originally Posted by chrisa7164 View Post
    sounds like you are going to put a lot of weight there. You would probably be better off building the frame rather than utilizing a chassis..To fit some of the various body styles the installers would have to remove cross members weakening the frames. Dodge had a problem with the 3500's cracking on wreckers and coffee trucks because of the missing crossmembers..
    What kind of bed would require to remove a cross members. All that I have ever seen/had installed above the frame.
    Miller Trailblazer 302
    Miller 12 RC wire feeder
    Miller HF 251D-1
    Miller 175 wire feed
    May 2009
    Massachusetts
    42
    canteen truck bodies..and some of the wrecker's..In the mid 90's Dodge was having trouble with the frames cracking behind the cab. I don't know if they issued a recall,but I know they had a kit to repair them..The body shop at the dealership I worked for did quite a few of them.
    Robbie, how about the alternative of putting that top-heavy service body on your truck, and just making the trailer be the back half of a pickup, complete with the original box? I sometimes tow a trailer with my service-bodied truck, works good enough.
    Mar 2009
    central ohio
    16
    The local tractor junkyard uses a enclosed van body to haul around his tools.I belive he used a trailer axle under it.
