Results 1 to 10 of 11
Thread: Branding Irons
    Apr 2007
    Nothern Colorado
    59
    Default Branding Irons
    Ok fella's, who can give me some tips for making up some sets of branding irons (hot irons). I need a full set of numbers and letters as well as a couple custom irons. I've never made any irons before but I know a few of you have. What are the do's and don'ts? Thanks guys.
    Oh, btw, if anybody knows of a pipeline kicking off, maybe you could let me know....
    i just made mine out of 3/8" flat strap heated and shaped to how i want it then welded the handles on. been using the same ranch brand and number set for i dont know how many years. horses getting freeze branded now only the cows are getting smoked
    MM 251
    DYNASTY 200DX
    SPECTRUM 625
    STARTS AND STRIPES BIG WINDOW ELITE
    Apr 2007
    Nothern Colorado
    59
    Did you notch out the corners to prevent blotching? How about the freeze brands, stainless or carbon?
    Sep 2008
    southwestern ohio
    272
    could you explain this freeze branding?
    Apr 2007
    Nothern Colorado
    59
    Freeze branding is basically the same as hot branding but instead of heating the irons, you super cool them. Instead of burning the hair and hide, it freezes the pigment folicles in the hair but not the growth folicles. So unlike a hot brand you get white hairs in the shape of your brand. This is done allot on horses, but not much on cattle. Actually some states don't even recognize freeze brands on cattle.
    on the corners i just took a triangle file and relived out the corners
    i used copper bus bars i had from work for my freeze brands welded them togethor with the tig machine
    for freeze branding the brands are dipped in liquid nitrogen or a mix of broken up dryice and 99% alcohol
    the Liq n2 works better -210deg C as solid co2 is -78.5deg c also theres less infection risk and faster healing times with freeze branding. theres a couple show cattle barns i have built freeze brands for since it looks better also. you can get more detailed information in a small freeze brand thats why the blm uses it for the mustangs and burros
    oh yeah bbj good name....
    MM 251
    DYNASTY 200DX
    SPECTRUM 625
    Sep 2006
    Okotoks Alberta Canada
    919
    Default irons!
    I made a set this spring for a rancher, I posted the pics, take a look and see if it helps!
    DODGE 1 TON 6.7
    PIPEPRO 304
    TO MANY TOOLS
    JUST WELDING IN CIRCLES
    rig welders are like wheelbarrows hard to push around
    and easily upset
    go flames go
    Nov 2005
    109
    Default Branding irons
    Hi I have cut out some branding Irons out of 3/8 and 1/4 plate just for fun I have used to brand my gloves boots wallet a few western type picture frames but its only for fun and they dont get used as often as a cattle branding Iron but you can cut very intricate parts
    like mine which is the out line of the state of TEXAS with my little boys initials inside of it or jus my initials hope it helps
    Lodi, CA
    1,262
    Freeze brands don't necessarily leave a permanent impression inside the hide; also, they don't leave evidence of subsequent modifying or tampering with existing brands, that can easily be seen with normal hot brands.
    Biggest mistake I see people make with branding irons, is using too heavy, and too close, iron. Tends to blot and blur. Take a field trip, talk to guys, look at brands, look at irons. If possible,,, watch it being done. It's more of an art than a science, building the things,,, and if you can't stomach the actual application, you probably shouldn't be involved anyway.
    Jan 2009
    Nebraska
    24
    Smile roughstock
    dam i wish they freeze branded bulls and broncs it would be a lot easier to see
    serious welder lol!!!!
    hobart 140 handler
    dewalt mitor saw
    makita grinder
    dewalt saw
    dewalt drill gun
    a nice hammer
    and some clamps
