Results 1 to 10 of 10
    Default Tig welding Iron gate
    Hello I have Dynasty 200DX and experience welding mild steel aluminum stainless. Someone has asked me to cut and extend a ornamental iron gate from say 50 inches wide to 55 inches. Can I tig this? What filler would I use?
    thanks
    The DX200 is a great stick welder. That is the route I would go. Less hassle and not much to carry.
    3,929
    For TIG i would use 70S-3 or 70S-6 1/8" filler rods...Bob
    May 2009
    5
    Default Iron gate
    Quote Originally Posted by LA Weld View Post
    I would follow LA Weld instructions to use stick. You didn't say how tall the gate was but stick welding is way stronger. Whether you are welding outside or in.. Especially outside with the wind.. Your gas will be blown away and it will be a waist. I think that you should stick it. Just my thoughts. Welder 35 years.
    Snowman6058
    Apr 2008
    171
    yes the 200 is a great stick welder
    i stick welded these balusters with the 200
    Mar 2008
    Anchorage AK
    344
    Are you sure the gate is IRON and not just painted steel?
    Mar 2008
    Anchorage AK
    344
    Quote Originally Posted by snowman6058 View Post
    Snowman6058
    On what planet?
    lexington,Ky
    528
    Quote Originally Posted by FATFAB View Post
    On what planet?
    Good one!!
    turbo38t Guest
    LOL......you are always makin me laugh :-P
    On what planet?
    Deltaville, VA
    2,239
    Maybe the way Snowman "tig welds", his stick welds ARE stronger.
    But, I thought we were talking about the "process" here. If that's the case, then tig is stronger and would require much less post-weld cleanup.
Tags for this Thread
