For those of you that dont look at Hobart. We are not a quick lube so I came to the conclusion that the jug on the bottom would be more work than it was worth so I just made a stand to sit the pan on which is adjustable for height. An old chair was the base and fence posts made the verts.
Once I came up with the plan took about 30 minutes and I re-tuned it for height again, put a hanger made from a welding rod and hose clamp to hang the wrench which has a nasty habit of disappearing every time I need it. There is a set screw and the pole is telescopic.
Results 1 to 3 of 3
Thread: Drain pan
05-16-2009, 12:28 PM #1
- Sep 2005
- 4,245
Drain pan
05-16-2009, 12:59 PM #2
- Sep 2005
- 4,245
A little tool cart to reside by the hoist that I whipped up along with the drain pan.
05-16-2009, 12:59 PM #3
- Sep 2002
- Clark County, NV
- 2,696
Nice! I'm usually trying to find a pan thin enough to slide under the car!
