Results 1 to 10 of 15
    Apr 2009
    Augusta, GA
    274
    Default Thing made with 1/4" base plate and 2pcs of 2.5" tubing.
    I made this to set on my table to keep my 18" tig filler rods in after i cut them in half from 36".
    It is a 1/4" base plate, with (2) 2.5" tubing side by side.
    Base plate is 6.5" x 4".
    It was tig welded with my Sync 200. Used 1/16" 309L filler. 3/32" tungsten (1.5% Lanthanated)
    I should of came up with a better design.. looks kinda funny.. hahahaaa
    Apr 2009
    Augusta, GA
    274
    Jul 2007
    Lancaster, Pa
    431
    I don't think it looks funny at all. You did a much better job with the welds than I would have done.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Apr 2009
    Augusta, GA
    274
    awesome.. thanks.. I still want to figure out something else to make so I can TIG it.
    Mar 2007
    Deltaville, VA
    2,239
    Use a lot of filler, huh?
    2 1/2" pipe will hold "A LOT".
    Nice job, regardless.
    Jul 2007
    Lancaster, Pa
    431
    Look through the projects board here and I'm sure you'll find quite a few ideas to use.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    2009 FXDC
    Mar 2008
    Anthem, Az
    31
    Pretty Welds. I havn't welded SS yet. I'm gonna have to find a project for myself.
    DAVE Dynasty 200DX with Coolmate 3
    Millermatic 212 Auto Set
    Millermatic 140 Auto Set
    Hobart Airforce 400 Plasma Cutter
    JD2 Tube Bender
    Apr 2009
    Augusta, GA
    274
    Quote Originally Posted by SundownIII View Post
    Yeahh, I should of used a tad bit more, but I am starting to become real real comfortable tigging, haven't been tig welding for too long, just every now and then. The walls of this tubing is .080".
    Apr 2009
    Augusta, GA
    274
    Quote Originally Posted by Shamrock1123 View Post
    Thanks, I'm always working on making them better each time...
    Default Filler Rod Holder
    myistar -
    Looks good, how far did you have your tungsten sticking out on the bead in between the two tubes?
    ---Machinist playing weldor---
    TA 185 AC/DC
