I made this to set on my table to keep my 18" tig filler rods in after i cut them in half from 36".
It is a 1/4" base plate, with (2) 2.5" tubing side by side.
Base plate is 6.5" x 4".
It was tig welded with my Sync 200. Used 1/16" 309L filler. 3/32" tungsten (1.5% Lanthanated)
I should of came up with a better design.. looks kinda funny.. hahahaaa
Results 1 to 10 of 15
05-16-2009, 11:54 AM #1
Thing made with 1/4" base plate and 2pcs of 2.5" tubing.
Syncrowave 200
Millermatic 211 - Awesome!!!
05-16-2009, 11:55 AM #2
Syncrowave 200
05-16-2009, 12:01 PM #3
I don't think it looks funny at all. You did a much better job with the welds than I would have done.
Ken
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
05-16-2009, 12:05 PM #4
awesome.. thanks.. I still want to figure out something else to make so I can TIG it.
Syncrowave 200
05-16-2009, 12:17 PM #5
- Mar 2007
- Deltaville, VA
- 2,241
Use a lot of filler, huh?
2 1/2" pipe will hold "A LOT".
Nice job, regardless.
05-16-2009, 12:19 PM #6
Look through the projects board here and I'm sure you'll find quite a few ideas to use.
Ken
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
2009 FXDC
05-16-2009, 12:25 PM #7
Pretty Welds. I havn't welded SS yet. I'm gonna have to find a project for myself.
DAVE Dynasty 200DX with Coolmate 3
Millermatic 212 Auto Set
Millermatic 140 Auto Set
Hobart Airforce 400 Plasma Cutter
JD2 Tube Bender
05-16-2009, 12:25 PM #8
05-16-2009, 12:26 PM #9
05-16-2009, 04:26 PM #10
- May 2009
- 58
Filler Rod Holder
myistar -
Looks good, how far did you have your tungsten sticking out on the bead in between the two tubes?---Machinist playing weldor---
TA 185 AC/DC
