Results 1 to 10 of 10
Thread: Hole in axle
    Oct 2008
    Oregon
    193
    Default Hole in axle
    I am using some old riding lawnmower axle shafts in my new welding cart.
    I inserted them in the ends of .065 wall, 1 inch square tubing.
    I drilled and tapped a hole to 1/4 x 20 thread, for a set screw.
    I need to make a depression, or hole for the set screw to fit into.
    My drill dosen't seem to make a dent in it, will my end mill do it?
    What other methods are available?
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
    Ohiowa, NE
    265
    Why not just weld them on?
    Miller Trailblazer 302
    Smith Torch Outfit
    Lots of Grinders
    Miller Elite Autodark Hood
    O'l Trusty Jackson
    3,945
    Drill a 3/8" hole in the tubing and plug weld them...Bob
    Oct 2008
    Oregon
    193
    I'm allowing for a future wheel width change and will need to adjust the length, that's why I don't want to weld it.
    Milwaukee Hole Hawg
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    1997 Suzuki DR650
    1,895
    Mark the axle & then use your grinder to make a flat spot on it for the set screw.
    Dec 2008
    Arizona
    812
    Your end mill should be able to handle it.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Oct 2008
    Oregon
    193
    Thanks .
    Milwaukee Hole Hawg
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    1997 Suzuki DR650
    Jan 2009
    Cleveland, TN
    229
    Quote Originally Posted by ligito View Post
    Sounds like hardened material to me (drill rod, oil hardened, thompson shaft) You can either grind it, or use a SOLID carbide bit on a slow speed to drill it.
    Dynasty 200 DX runner
    Sync 350 LX
    XMT 300 w/D74 and roughnecks
    Hobart 135
    ESAB PowerCut 875 plasma
    Feb 2008
    893
    Those axle shafts are case hardened up to the splines.
    Drilling it would be just like drilling through the shackle of a padlock.
    Use a Dremel and grind the dimple or use a carbide bit. A HS end mill will bite, walk, then shatter. You could use a carbide tile drilling bit in a drill press.
    About 3/16" deep, it's much softer.
    But I think you will have trouble holding it with a setscrew.
    Oct 2008
    Oregon
    193
    I read the last post after my HS end mill bit, walked, then shattered, on both ends.
    I don't have any carbide end mills yet.
    I ground a flat but would feel safer with a dimple, or hole, so I guess I better get a carbide 5/16 end mill.
    Milwaukee Hole Hawg
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    1997 Suzuki DR650
