Hi !
P#2
Im looking for two informations:
1- lenght of the spark generated by the Econotig arc starter.
and
2-information for the Econotig arc starter electronic circuit diagram.
In March I receive an Econotig tig welder that the arc starter is very short, no more than 0.5 milimeters. This make the initiation of the weld very dificult.
What is the lenght of the spark, generate by the arc stater when the main current supply is off ??
I need the information for the Econotig arc starter electronic circuit diagram to chek and repair the arc starter. Actually the problem with the Econotig was solved with the addition of one arc starter unit manufctured locally. The machine works well, but is not the appropriated solution.
So I need the circuit diagram for the arc starter board to check the Econotig.
A circuit diagram for the Dynasty or for the Diversion, even for the Maxtar will give valuable information that will allow I fix my Economy...
Please not Im in Brazil, far away from the best supplies... Email for newton.b@live.com, please.
Newton Brawn
-newton.b@live.com-
Results 1 to 1 of 1
05-13-2009, 01:29 PM #1
- Aug 2008
- Toronto
- 26
arc starter circuit diagram schematic
