Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    illinois
    101
    i have still yet to order the fittings,vent and the cap. really in no hurry to get it in will pry do it this winter and tub the car at the same time. i was just looking for something to weld to try out the welder, on the other note i still have to cut a hole in the top for the cap i figured i could just put my hand through the hole before i put the cap on to put the bulkheads in. then use a shop vac to get all the shavings out.
  2. #22
    Apr 2008
    Bohemia, NY
    47
    you should be able to get it clean then. Just make sure you get everything out and you are goin to presure test it right.
    Thermal Arc GTSW300
    Syncrowave 300
    Handler 125
    Acorn Table
  3. #23
    illinois
    101
    yes im going to weld a threaded 3/4 pipe to the top in the middle of the circle for the cap to put air to it. use soap and water to test it then cut out the circle.
  4. #24
    Apr 2008
    Bohemia, NY
    47
    how much time do you have into the tank? how big is it? and where did you get you material?
    Thermal Arc GTSW300
    Syncrowave 300
    Handler 125
    Acorn Table
  5. #25
    illinois
    101
    as far as time, probly a hour and a half. it is around a 5 gallon tank measures 12x12x8. i got the material through my work so it pry came from ryerson or alcoa.
  6. #26
    Apr 2008
    Bohemia, NY
    47
    thats not bad at all. I love getting material from work. I have built a few tanks that way. Did you shear it at work too. And once again very nice.
    Thermal Arc GTSW300
    Syncrowave 300
    Handler 125
    Acorn Table
  7. #27
    Mar 2009
    11
    yeah those are nice.....J.R. teach ya that???
