Hi Squig.... just bought some 4 1/2" off ebay at a good price and curious to know how thick a material you cut with them (curves, etc.)
Here is info and a source for these Walter ZIP CUTS:
http://www.industrial-supply-store.c...f4zbbu8ACo.php
Results 21 to 26 of 26
Thread: 2050 Plasma cutter
01-08-2008, 05:15 PM #21
01-10-2008, 05:33 PM #22
- Nov 2007
- 36
Miller 2050 plasma cutter
Hey Lu47Dan; I use the 2050 all the time instead of the torch even doing pipe work. Power it off from my miller 250 trailblazer. Things that I wanted when I bought the 2050 was being able to cut stainless, alumimun, and steel along with being able to be portable, and being able to handle material immediately. Never used it's scarfing feature since I use an air arc alot also. Will use a torch when you have to reach into a bad area that the plasma can't get too and also if I have a lot of heavy metal to burn. If you plan on using a plasma in the field, remember the weigh that you will have to handle. Well worth the money if you have enough business to justify buying.
01-10-2008, 06:26 PM #23
this might not go over well here but i have had nothing but the best experience with hyperthrem 1000. in my opinion it is better than my 2050 miller
. just plainly the best one i have used so far and i have used almost all of them.
trail blazer 302
hypertherm plasma
millermatic 251
high feq. arc starter
suit case (extreme 12vs)
o/a torches
02-03-2008, 11:12 PM #24
Update on the purchase of the Spectrum 2050 Plasma
I bought the 2050 last summer , and really like it
. I added a Motor Guard filter to it to keep the moisture and the dirt out of it . The 2050 has done everything I have asked it to do and I am well pleased with its performance . Like anything it had its learning curve
. Dan
Tools to Men are like Shoes to Women you can never have too many .
Miller XMT-304
Miller Spectrum 2050
Miller 10-E Feeder
Hobart 175 Handler
Lincoln AC225
And assorted others
12-06-2010, 06:07 AM #25
- Dec 2009
- 62
Miller 2050 on clearance
I know its a bit late for this thread, but the Miller 2050 plasma cutter is on great sale at Grangier for $1046-
http://www.grainger.com/Grainger/MIL...928?Pid=searchMillermatic 211
Everlast 200DX TIG
Lincoln Weld-Pak 100
Century Stick welder
Hypertherm Powermax 30 plasma cutter
Oxy set-up with Henrob 2000 torch
Logan 200 lathe (60 years old)
Jet band saw
12-07-2010, 02:27 PM #26
- Sep 2005
- 4,242
That price doesnt sound right. I called, it sounds like they are out of stock but the service rep sounded kind of confused??
