Results 1 to 9 of 9
    May 2009
    7
    Default Grill grid question in stainless?
    I'm new here and have a question about a grill grid for my grill. The replacements are over $180, so I was going to get a new grill this year after 20+ years with the old one. But since I was laid of work and don't see anything coming up soon I need to go to plan "B", and rebuild.
    I have only TIG welded stainless but since I don't have a TIG I'll need to stick or MIG weld it. I am leaning to stick because of cost (tank, gas, wire). Any suggestions would be great. I might have a small tank with nitrogen that I could swap for a mix gas but would have to check. Not much welding just a bunch of tack welds.
    I checked the garage and I have a small tank about 14" tall of CO2, and a taller (around 18") and fatter tank of nitrogen. I also have this same size tank of C-25.
    Also to the grill builders out there, any idea on what size stainless rod and the spacing I should use. This is a high end nat. gas grill so with this rebuild I'll be keeping it for another 10-20 years.
    Todd
    Oct 2008
    Oregon
    193
    I'm thinking 14 Ga. or larger and spacing adequate enough to keep food from falling through.
    What is the spacing of the original?
    If you space to closely, you add more work at clean up time.
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
    Salem ,Ohio
    3,954
    Cool
    I made a few custom grills last summer and i just used 1/8" 304 tig rod that i got by the lb from my LWS. It was pretty cheap and worked well. I migged the ends together...Bob
    Dec 2008
    Arizona
    812
    Are we talking the cooking grate or the one that holds the lava rock?
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    cast iron grates are the bestest IMHO
    watch ebay you can find what you need cheap
    May 2009
    7
    Quote Originally Posted by nocheepgas View Post
    Yes, cooking grate.
    May 2009
    7
    Quote Originally Posted by ctrhenry View Post
    I checked ebay and I found a cast SS replacement for $275 + shipping that look nice. But I can't spend that much now. And a porcelain coated steel one that looks cheap (thin wire) for $75 with shipping.
    1/4" SS rod will cost me around $45 for 1/2" spacing. I might go with 5/16 or 3/8 and increase the spacing.
    Thanks,
    Salem ,Ohio
    3,954
    Cool
    Some Cast iron grills...Bob
    http://www.roloffmfg.com/barbecue.asp
    Dec 2008
    Arizona
    812
    I wouldn't consider anything less than 1/4" for the cooking grate.
    130XP MIG
    Spectrum 375
