Results 1 to 2 of 2
    Canada
    Default First welding project with MM180
    This is my garbage can holder that i made with my MM 180 and is my first project. I used 1 inch angle iron for the lower frame and solid square tubing for the upper part of the frame and a piece of plywood for the base.
    Oct 2008
    Oregon
    193
    Solid square tubing?
    Is it solid, or tubing?
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
