    Default firewood dumbwaiter?
    I'm looking to build a dumbwaiter for use for firewood. This unit needs to travel from ground height about 8' up to a sun deck. I picture using an ATV cable winch where the winch is at the bottom, pulley at the top that pulls a box of some sort up with the wood inside for unloading. Weight of the box via gravity descends the box to the bottom. Pretty basic design I suppose but I'm wondering if anyone has made something like this, has pictures, plans etc.
    If not, any ideas, suggestions etc?
    (this is of course so that my kids can do firewood now rather than me schlepping it up the flight of stairs to our living room!)
    Piper
    WY...armpit of U.S.A.
    659
    No plans or ideas, but be sure to add a limit switch or the kids will bring the whole house down around your ears.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    2,914
    2,914
    Oct 2008
    Oregon
    193
    Quote Originally Posted by Northern Piper View Post
    Piper
    Let the kids schlep it up the stairs. Builds muscle and integrity.
    Be careful, so what you build doesn't end up falling on someone.
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
    Jul 2006
    19
    Northern sells a low-end electric winch with mounting hardware (four bolts to whatever you bolt it to), they put them on sale a few times a year with free shipping.
    I've used them for light duty theatrical rigging.
    I'd worry about clipping someone's fingers off with a home-brewed rig like this, though.
    Lightbulb
    HF puts there electric winch on sail all the time. i have had mine for a few years now used mostly for lifting my riding mower to clean under the deck or remove the deck. it comes with a pulley to double the lifting capacity and slow it down as well. it has a built in stop switch and runs off 120V. thats what i would use for a power lift.
    i agree 100% about the lil fingers, so maybe let them load but don't plug it in till they come up and tel you its ready to lift with you watching. depending on there age and responsibility level. i would build an outer cage door that must be closed to allow power to the lift ( just like an elevator)
    i have this one.
    http://www.harborfreight.com/cpi/cta...emnumber=44006
    good luck and be shore to show us what yo end up with .
    May 2009
    The Colorado Gas Patch
    185
    My thoughts on the project are,
    A hydraulic ram inside a pipe in the ground, put limiting orifices in the ram fittings this would prevent a runaway in case of a hose break. if you have a wood splitter all you would need to do is install quick disconnects for both rams. Hydraulics has safety advantages due to pressure control adjustments in the spool valves..
    The lift needs to be enclosed with safety limit switches switch or exposed with no pinch / entrapping points...A basket attached via rollers to an I beam (tilted or vertical) would be a good conveyor system..
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Looking at CNC Plasmas
    It's Miller Time - Get Back To Work!
    Jul 2006
    19
    i have this one.
    That's the one I used- mine had four threaded mounting holes in the sheet metal body that took supplied metric bolts.
    Using this winch within it's limits can get you a lot of bang for your buck.
    ...now I gotta buy another one after all this
