    Default Tig for Beginner
    I've been welding for a few years now and have a MM180 mig welder that works great.
    Anyway i'm looking to start on tig and wondering about a good machine.
    I really like the Syncrowave 200's but i have found a used 180 for a pretty good price and wondered what you would think about that.
    I would use it for hobby only and would weld steel as well as aluminum probably no more than 1/4 in.
    I would like to save and buy a syncro 200 but if there isn't much difference and i could get a 180 for cheap than i would.
    Anyway i'm just looking for your thoughts and opinions for a newb?
    Thanks Brent
    Ocean City, Maryland
    951
    I have a synchrowave 180 I bought about 3 yrs ago. Its great with no problems. 1/4" or less is good. The new invertors are the best but pricey, if I had to do it again I'd buy what I have. What kinda price are they asking and how old? that would be my deciding factor.
    good luck
    Scott
    HMW [Heavy Metal welding]
    He's asking 800. It doesn't say how old but he claims it only has 6 hours of use.
    The manual for the 180 is online, there is a sequence at power-up that will show the hours useage on the digital display, check it out.
    I gave $1200 for a 180 syncro last fall with less than 10hrs showing on the meter, works great for my stuff.
    Be aware that you will have a sizeable investment in consumables, much more so that a mig. The advantage of a TIG IMO is the ability to have full control of the weld puddle, however in order to take full advantage you'll need a wide range of tungstens, collets, cups and filler sizes. Tig is not nearly as "one size fits all" that MIG is..........
    Tom
    951
    Yeah TDKKARt is right you can tell from the digital meters how many hours are on it. Sounds like a good price. As far as consumables they make a little starter kit that has the 3 most comman sizes in it. 1/16", 3/32" and 1/8". That will do about anything you want. I added .040 to mine and only used it a little. Mostly 3/32" it seems. The tungsten is where it gets you. If I had to pick one size to learn with it would be 3/32"
    Scott
