    Default Welding cart for Passport
    Here is a quick cart I made from Left over office chair parts and a little flat stock. the sleds slide into the pass port side rails and the old chair hight adjustment holds the unit in place with lid open or closed.
    Nov 2007
    Central Idaho
    190
    Great idea. Very creative.
    Indiana
    25
    Nice work, man! Willing to share the step-by-step procedures on how you created it?
    Pretty simple stuff realy. I just made a set of split rails out of 1" flat stock to fit into the slides on the side of the Passport case. I also used a bender to follow the curve of the case, however, one could have just welded a 90 degree stop if they wanted to. On the back I used the chairs back rest and altered it slitly to create a hook and used the slide to hold the welder in place. (this is a nice feature, as you can adjust for having the case closed or open) After that it was simply adding my casters, torch holder and cable hook.
