Results 1 to 10 of 11
Thread: Garden trellis
    Jan 2009
    Jennings, LA
    50
    Default Garden trellis
    Completed trellis finially
    Garrett R. Durio
    Millermatic 180
    Dewalt 14" chop saw
    B&D 7" grinder
    Skill 4 1/2" Grinder
    www.myspace.com/garrettdurio
    Central Iowa
    72
    Like the back feet. I had been thinking about doing that myself.
    Nice job.
    3,928
    Nice job on the arbor.
    Here is one i made. The arch was a little bigger but the ladies love them...Bob
    Jan 2009
    Jennings, LA
    50
    Like the hooks
    Garrett R. Durio
    Millermatic 180
    Dewalt 14" chop saw
    B&D 7" grinder
    Sep 2008
    Dalton, GA
    128
    Default Trellis and Arbor
    Great work, guys. I want to build both a trellis and a walk through arbor.
    Would you mind posting the details like dimension and material used? I'll come up with my own design pattern, but knowing how heavy material to use would be a great help!
    Burt
    _______________________
    Miller 211AS
    Miller 375
    Miller Syncrowave 250
    Miller Thunderbolt XL
    http://www.10FtDrillBit.com
    Central Iowa
    72
    Bob, do you do anthing different on your "feet" to support the weight on the hooks?
    I keep having mine fall over (especially just a one sided hook)....course my feeder hold too much food !!!
    I just saw a square design I though about trying, with four pieces sticking into the ground.
    Ed
    3,928
    When i designed my hooks 8 years ago i did something different than everyone else. They all use a seperate rod bent 90* and now you have to pound 2 pcs of rod into the ground. I can pound my hook thru blacktop and i have done it at craft shows. I cut the bottom of the shepherd hook at a 45 with my bandsaw then i cut a piece of 1/4x2" flat 7 inches long and its also cut on a 45 to cut the soil. Then i weld it on the hook so there is 10"-12" of hook at the bottom of the flatbar. So they are pounded in the ground 18-19 inches and they will not tip. Thats what is nice about the flatbar because you can use a big hammer to drive them in if needed. I leave a small gap between the hook and flatbar one for weld penetration and the other to get paint in the crack. That flatbar needs welded on good and i have never had one break off. Those other guys hooks i fix at least a dozen a year with the China one tack on each side....Bob
    When i used to go to the craft shows i hung cement blocks on my hooks to show how good they stayed up.
    Central Iowa
    72
    So the flat is beside the main foot of the hook?? Like a fence post?
    3,928
    Yes the plate is welded to the barstock. The hook is on the left side.
    wb4rt the rod i use is 1/2" sq so i can twist it...Bob
    looks great guys, now if i could just get my roses to grow. then i would have an excuse to make some too.
