Results 1 to 7 of 7
Thread: new tig machine
    Default new tig machine
    i am pondering on what tig setup i want. i will only really use it at home, and dont really need anything to weld thats 1/4 inch. i am hoping to spend no more than around 1500 or so. do all tig machines need cooling systems? and i also want my machine to be capible of welding aluminum. i want to buy new with warranty also. thanks for your advice. Joe
    Riverview N.B. Canada
    64
    Hi
    The entry level Miller AC/DC machine is the Diversion . It gets good reviews and it seems to be right about in your price range . I would start there if I were you.
    Quote Originally Posted by Mustang View Post
    Hi
    i need something i can plug into a 115 recepticle.
    Jan 2008
    Colorado
    673
    Well that eliminates the Diversion, Syncrowave and TA-185. And alum pretty much eliminates the harbor freight doo doo because you need AC also. Next up is the Dynasty, twice your budget.
    The only good news is: No, all TIGs don't need coolers.
    RETIRED desk jockey.
    Miller Syncrowave 250.
    San Diego, CA
    42
    Quote Originally Posted by loolagigi View Post
    You we be lucky if you could get 100 amps out of even the most efficient machines running off a standard 115 volt/15 amp outlet. (only useful for welding materials under 3/32" thick.) Under 100 amps you would not need a water cooled torch, a #9 or #17 torch would do. A water cooled torch would be useful when welding continuously over a 100 amps, tungsten holds up longer and the torch wont melt in your hand.
    Augusta, GA
    264
    yeah, as said already, the Diversion165 would be your best bet, and just get a 220v line installed.
    Syncrowave 200
    Millermatic 211 - Awesome!!!
    Jan 2009
    wisconsin
    22
    with your price range go get the diversion and put a 220 plug in the garage
Tags for this Thread
