Results 1 to 8 of 8
    Feb 2009
    199
    Default polishing stainless & aluminum to a mirror finish
    Aug 2007
    Central Fla.
    311
    Looks good. Would you care to elaborate on the process you used for the benefit of the community?
    Also, if you haven't tried it, look for some "Yellowstone" polishing compound. You'll like it I think.
    Umatilla OR
    12
    Default mirror finish
    I have worked with stainless for many years and still haven't mastered it yet. I use basicly the same system but I seem to have better luck with gray or white compound. I can't get all the micro scratches that the cotton pads leave. I started out with #8 mirror finish matieral on this project that was damaged in shipping.
    Feb 2009
    199
    the grinder with the big wheel is what we call a grey wheel it is made by bear-tex series 1000 made by norton this is for deburring & blending .......heres a few links & lots more if you search....
    http://www.ind.nortonabrasives.com/M...e%20Wheels.pdf
    http://www.youtube.com/watch?v=Ucm4E...eature=related
    http://www.youtube.com/watch?v=Vp-aL7ega5o
    http://www.youtube.com/watch?v=9bBYy...eature=related
    Mar 2007
    Oahu, Hawaii
    2,469
    thunder......WOW!! Great tips and Great Sites!!!!!!!! THANKS!!!!!!!!!
    What is that portable air sander you use?
    I'm not late...
    I'm just on Hawaiian Time
    Apr 2005
    Saskatoon, Saskatchewan
    220
    I've done my share of polishing...lots of labor and it sucks when even paper towel can scratch the surface!
    I use an pnu. orbital sander starting at around 300 grit and work my way up to 600 or so, then some emery cloth at 1k grit. Then onto the Baldor buffer (different wheels of course...).
    For SS I use:
    Rough Cut - Sisal Wheel with Black Emery Compound
    Final Cut, Rough Polish - Sprial Sewn Wheel with Green Compound
    Final Polish - Loose Cotton Wheel with Green Compound
    Wax (optional) - Anything carnuba based
    For AL I use:
    Final Cut, Rough Polish - Sprial Sewn Wheel with Brown Tripoli
    Final Polish - Loose Cotton Wheel with White Rouge
    Wear glasses and mask, unless you like black snot. Also after washing your face make sure you wash around your eyes...or you'll look like an 80's rocker with makeup around the eyes. Polishing is messy work.
    Some things I have polished:
    Polished SS
    Polished SS and Acrylic
    Polished AL box, mediablasted after
    Thermal Arc 185TSW, Lincoln SP135+, 4-post automotive hoist, 2x media blast cabinets, 50 ton press, 80gal air compressor, 4-1/2"x6" bandsaw, 4'x4' Torchmate CNC table with plate marker, Hypertherm Powermax 65 plasma cutter, ultrasonic cleaning stations
    Apr 2005
    220
    Intercooler polishing in progress...not fun using the Baldor while holding such a large/heavy piece. Haha.
    Some AL to show the quality of a flared hole.
    Aluminum sanded with the orbital sander (around 300 grit)
    Done!
    Dec 2006
    612
    I've polished some aluminum parts. These are polished up to the final step. I figured I'd give them the final polishing when it goes together for the final time. The center section housing is cast aluminum, some are machined on a lathe & some are CNC cut from used plate from the salvage yard.
    That is some cool stuff Conrad Turbo.
