Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Feb 2009
    202
    if your close by i will do it for FREE & guarantee it...i'm in NC...
    Mar 2007
    Deltaville, VA
    2,239
    Just because it might be "done everyday" doesn't make it right and it sure as he11 doesn't make it safe.
    The OP is getting some bad advice here. There's a reason why pressure vessels are certified.
    Thunder, you seem to be one who likes to go against generally accepted industry standards (using pure tungsten in an inverter) and welding on pressure vessels without the proper credentials.
    I'd like to be the lawyer representing the plantiff when one of your "out of the box" solutions blows up and injures or kills someone. I guarantee you don't have enough insurance to cover the potential damages.
    I've seen some of your work and it's good. I don't understand your position on this issue. A dang $100 tank isn't worth someone getting hurt over. To recommend stick welding that tank without having a clue about the OP's "welding experience" is just flat out reckless.
    If it was absolutely necessary to add a motor support to this existing tank, I'd fabricate a bracket with a saddle that fit over the circumference of the tank and braze the saddle in place. Lot less chance of changing the metalurgy of the existing tank.
    Feb 2009
    202
    Talking
    don't listen to me i'm just a dumbass without a clue....but with experiance & i do it almost everyday with the dynasty 350 use 100% green tungsten with good results but you know it all comes down to the operator of the machineyour right i don't know if this guy can weld or not he did not say...in my day i was boiler & pressure vessel certified & was qualified to use the "R" stamp without ever having any problems...............................
    Quote Originally Posted by SundownIII View Post
  4. #14
    Apr 2009
    A State of Confusion
    143
    Wow! Things I did not know about welding pressure tanks this thread has been somewhat educational for me.
    Although Iíve done a little bit of welding on a tank or two.
    Hereís a pic of one of those tank I did little welding to after welding up all the holes I think it came out ok. LOL!
    But in all fairness and a logical point I personally would just buy a tank that would give me enough room on the platform to accommodate the motor and pump. Safety should always come first!
    Many years ago I watched my dad build his own compressor needless to say it did work for awhile but it did fracture on a couple of welds luckily no one got hurt as we all worked around or in the same vicinity, so all the work he went through seemed to me be more of a cost than just buying a new compressor for a few dollars more with no worries. Sheeeew that was 30 years ago.
    Compressors can be bought cheap enough in todayís market usually just a few dollars more than the cost of the materials, consumables and labor it takes to modify and repair one.
  5. #15
    Jun 2004
    nj
    204
    Don't modify the tank. Build a frame to hold the tank and the pump independently.
    I'm going to guess that seattle smitty is in Washington state based on the name. Start with the rules: http://www.lni.wa.gov/TradesLicensin...Book012009.pdf Note the LEGAL requirements for doing repair on a pressure vessel (in the 296-104-500's), and note that there is exemption for unfired vessels less than 5cuFt (about 40 gal) (sec 70.79.080) A 40gal tank at 100PSI is one heck of an explosive device. There is a photo floating around (in the previously mentioned thread, I Think) of what a tank of about twice this size does to a locomotive when it lets go.
    If there is a failure (probability low, but decidedly not zero), what is the penalty? (probably high) What will your insurance do if you make an alteration, though technically legal, and a failure occurs, even if what you do has nothing to do with the failure? If your insurance company finds out you do this, will they just cancel the policy (hint: it is quite possible. read the policy) retroactively (they can do this too, and then nail you for fraud.) These are things that have happened locally to me in the last year. My AI was involved in investigating a brutal one in a school (no injuries or fatalities, fortunately, since it happened at night) with about a 40gal tank for HVAC controls.
    This is not something to play at. Failures don't happen often, but the price is high when they do. Kind of like with an oil refinery.
  6. #16
    Apr 2007
    Eastern Ontario
    101
    Pretty sure every one of those "factory welded" compressor tanks have to pass a hydrostat test before they are stamped as certified and then released onto the buying public.
    If you can get it hydrostat tested after you weld - go for it - no risk, no danger, if it fails, oh well. Otherwise, bolt something to the existing mounts or toss the thing.
    My 2 cents.
  7. #17
    Thanks to y'all for the input.
    I'm sympathetic to both sides of the argument. On the one hand, the money equation is that I could save several hundred dollars by customizing this tank, but I could lose everything, possibly including assorted body parts, on the downside. OTOH, I can certainly run a bead without undercut or slag inclusions, and tend to agree with Thunder71 that experts in many fields are sometimes known to describe what they do as rocket science, when any good craftsman can manage it when told how. I don't especially have a personal use for a pressure vessel welding certification, but this conversation has me interested in learning more about it, especially about typical tank metallurgy and consequent choice of welding protocol.
    As it happens, after getting this thread started, I took the head off the "no good" compressor that came on this tank and saw I could fix it, which I have done. This is a dinky little pump (i.e., slow) on a relatively big tank, and as I said, I have a bigger Speedaire pump. However, I guess I will sell this compressor and buy a tank for the big pump.
    I was looking at Home Depot's biggest compressor this morning, "Husky" brand. V-twin 2-stage pump, 175psi, 12.5 SCFM @ 90psi, 80 gal (IIRC) vertical tank, priced at $1100 plus tax. BUT . . . I could not see any approved-rating plate anywhere on the tank. I just don't like the idea of an unapproved air tank made of Chinese mystery metal!!
    Thanks again.
  8. #18
    Feb 2009
    202
    if you look at some of the new tanks you will see LOTS of $hitty welds
  9. #19
    Feb 2009
    Island Falls Maine
    562
    We can fight this all day but it wont do any good there are good points on both sides. Personaly I would just buy one I have to much going on too mess a round with an old compresser.
