Results 1 to 3 of 3
    Seattle,WA
    55
    Default where to find replacement parts for airco wire feeder?
    I am looking for a drive roll replacement part for a Airco Mighty IV Wire Feeder. The top drive roll is pretty worn out and is causing the wire to slip in the middle of when I'm welding.
    Welders do it hotter!!
    www.Munsonworks.com
    Jul 2007
    Batavia, NY
    159
    Arc Products
    1245 30th Street
    San Diego, CA 92154
    800-770-0063
    http://www.arc-products.com/
    This is where we get all our older Airco parts from. If you can't buy direct they may be able to give you someone in your area that can help you.
    Another common problem with those feeders is the clapper assembly, particularly the spring steel tension strip.
    Rich Ferguson
    Sales Technician
    Jackson Welding Supply Co.
    www.jacksonweldingsupply.com
    3,953
    I just custom made a drive roller for an Airco welder, don't know the model but maybe i can make yours...Bob
