    Dec 2008
    Arizona
    812
    Question A Wiring Genius I'm Not!
    I'm building a water cooler and need a little wiring help! I ordered a water pump from Miller designed for the Coolmate 1 (115v), heck it turned out to only be $51.00 and I knew it had to be up to the task. Here's the schematic:
    Looks simple enough, a hot lead and neutral/ground with a fan wired in parallel. I received it today, and here's what I got:
    And here's what the pump looks like:
    So the big question is how do I wire this?. There are 2 white leads with 16(?) gauge wire and 3 terminal connections on top of the motor.
    Any help appreciated!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    National City CA
    1,086
    Your two wires are going out to your fan motor. These are wired in parallel with the terminals. Check continuity from wires to to the terminals to determine which one is ground. but I'd be willing to bet it's the big lug thats in the middle.
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Auto shades are for rookies
    www.KLStottlemyer.com
    Dec 2008
    Arizona
    812
    Thanks, that was what I was thinking as a possibility.
    130XP MIG
    Spectrum 375
    Dec 2008
    152
    Quote Originally Posted by kcstott View Post
    Yep dead right
    Tennessee
    18
    Sorry, can't read...some **** popups are covering part of your diagram. Wonder why that happens?
    Jul 2007
    Southern NH
    233
    Quote Originally Posted by Chris Bar View Post
    dude just right-click his diagram photo and select "save-as" and then open the local file with your browser. some browsers you can even right-click and select "view image" and it views the image as a new page by itself.
    miller dynasty 350
    miller spectrum 1000
    Dec 2008
    Arizona
    812
    I'm not getting any continuity between the contacts on top of the motor and the white wires, doesn't that rule out it being for the fan? There is also a fusible link within the white wires and depending on how many amps the factory fan draws, 16-18 gauge wiring seems kinda small, but then again I tend to overengineer everything.
    130XP MIG
    Spectrum 375
    Oct 2008
    Oregon
    193
    Is there only a fusible link on one white wire?
    If so, that would be the hot wire.
    After looking at the scematic, I don't think it makes any difference on which wire you connect to the which terminal on the fan. it's just completing the circuit.
    Unless, one terminal is marked for positive.
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
    Dec 2008
    Arizona
    812
    Quote Originally Posted by ligito View Post
    Yes, fusible link on 1 white wire.
    130XP MIG
    Spectrum 375
