    Default "convenience items" added onto Roll around Mig Welders
    I just got my first Miller welder (used 250x) and I'm wanting to add on a shelf to hold a set of mig pliers, a pencil, tape measure, anti spatter etc. I also want a nice place to hang up the leads and my helmet. I don't want the shelf to get in the way of opening the door. I've seen a few different types of modifications (in fact, my dad and I made one for his MM 185), but I wandered if any of you had any slick ideas. Pictures would be sweet.
    3,959
    Here's my hose holder. Since i don't have my bottle on the back of my MM185 i don't have anywhere to hang my gun and ground. So i fabbed this simple hanger up from some stuff laying around the shop. You can add a simple shelf anywhere on it for your goodies too and it will swing out of the way. I put a bracket on the bottom rack and the rod then comes up thru the chain hole to keep it more secure plus it will turn in the bottom mount and can be removed in a few seconds. The bottle will still fit if i ever want to put it back...Bob
    Sep 2006
    Newcastle, Oklahoma
    70
    Check here and see if this is what you are looking for.
    http://www.millerwelds.com/resources...read.php?t=413
    Sep 2008
    southwestern ohio
    272
    I got an Idea a few months ago to store welding golves by mounting A spring clamp to the welding cart and clamping the gloves in it havent done it but it may help you if you are slightly disorganized
