Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Default Can you use a plasma cutter for this?
    I am going to cut open a propane tank for my next BBQ pit build. I plan to fill it with water and make my cuts. Anyway, I have done this with a torch before and had no problems, but I want a tighter cut. Will the plasma cutter work with a tank full of water, I was concerned with the potential to get the crap shocked out of me
    Ohiowa, NE
    265
    I would think that as long as the ground is attached directly to the tank, it shouldn't have any problems. Considering the fact that the CNC plasma table I used to use had liquid coolant touching the piece being cut, and had never gotten shocked.
    Miller Trailblazer 302
    Smith Torch Outfit
    Lots of Grinders
    Miller Elite Autodark Hood
    O'l Trusty Jackson
    4,513
    report back.
    Mar 2009
    Papillion, Nebraska
    19
    Cool More plasma cutter use
    Don't have a plasma cutter yet but am considering one. May be a dumb queston but; can you use the nonconsumable electrode with out the air stream to heat a small piece or area to red hot for forging etc?
    Feb 2008
    900
    I've gotten shocked hard enough to knock me on my butt from welding while wet, even being DC. But a plasma cutter uses a much higher voltage. I would DEFINATELY not use a plasma with water gushing all over.
    If you know anyone that does HVAC, perhaps they can pump it down to a high vacuum and refill it to 0 psig with nitrogen. Vacuum pumping evacuates all but trace amounts of propane, which would probably do the job on its own. The nitrogen performs the task of displacing oxygen thus preventing the remaining trace amounts of propane from forming an explosive mixture. And it does this without the drawbacks of cooling your cut and getting everything (including you) wet.
    Oct 2008
    taxachussetts
    416
    Quote Originally Posted by kmomaha View Post
    i've never seen a plasma that would arc with out the air. and if it did you'd just melt the lead. big money to replace.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
    Midland, Mi.
    313
    Put a few pounds of dry ice into the tank. As it melts it will fill the tank with CO2.
    Then cut away!
    Mpls, MN
    1,790
    As long as there's no valve on the tank when you put the heat to it, you'll have no excitement.
    I've cut numerous tanks with plasma and as long as you flush them with some form of purge (getting the bulk of the fuel out - which mostly happens without assistance due to the -44F boiling point of the liquid), there's little more than a small "whoosh" as the remaining gas is combusted. You can leave them inverted (propane is heavier than air) for some time as well, as that lets gravity evacuate the tank for you.
    Filling with water is a waste of time IMO. Dry ice is a nice thought, but also overkill.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Oct 2008
    taxachussetts
    416
    after you get it cut in half you'll have a way to put the block of dry ice in.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    miller 211
    evolution rage 2
    Quote Originally Posted by Bodybagger View Post
    Only takes once to get your full attention. Makes a fella a little gun shy about sticking another rod in the stinger, too.
