Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Oct 2008
    taxachussetts
    416
    may i suggest you google the tractor model and copy the OEM style for your forks.
    keep on mind that putting the forks on to the bucket will ad to the leverage point decreasing your lifting capacity.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
    Mar 2008
    Midwest
    109
    Quote Originally Posted by vin-man welding View Post
    Good point, done that this PM, appears Massey uses all after markets. Some similar to griff01 and gda suggestions. appreciate the inputs.
    Feb 2009
    Island Falls Maine
    562
    if it was me I would just look for a set of used ones at a scrap yard
  4. #14
    Mar 2008
    Midwest
    109
    Quote Originally Posted by m.k.swelding View Post
    M.K.
    Good point, logical, common sense. However, it takes all the fun out of the fab/welding
  5. #15
    Sep 2008
    Franklinville, NC
    3
    I might have posted these before, but here goes. Made from 2 in. channel and 1 1/2 angle. Channel on top angle on the bottom. 2- 3/8 bolts per side bolted from the bottom of the bucket. Hope it helps . I have a TC33 NH
  6. #16
    Mar 2008
    Midwest
    109
    Quote Originally Posted by gus203 View Post
    Thanks Gus. Appears you have the angle running under the bucket for support and a place to bolt the forks. Correct? Practical and straight forward. I'll show these to my friend and have him verify if he wants this type or a set that clamps on like gda's for width adjustments. I guess one could always drill more holes.
  7. #17
    Sep 2008
    Franklinville, NC
    3
    Thumbs up
    Thanks for the compliment, They have moved some good sized loads of logs. I know the limits of the FEL on my little tractor and would rather not over do it. That was the main reason for not over building the forks. Glad to help.
