Results 1 to 9 of 9
    Oct 2007
    Prairieville, Louisiana
    139
    Smile CNC Plasma Cutter . . .
    Just need an opinion from all you guys . . .
    My intention is to build or buy a CNC Plasma Cutter with a 4'X4' table. I want to operate it as a hobby machine for art / craft type of stuff. The reason for the small table, I can not imagine handling sheet larger, whether it be storage or getting on the table by myself . . . I'll be in a 2 car garage . . . :-)
    My question to you guys is based on your experiences, where would you try to hustle additional work for my table.
    I'm thinking, all types of shops;
    1. motorcycle
    2. 4X4
    3. utility trailer
    4. small fab
    5. welding
    6. machine
    7. boat dealers
    8. ornamental iron (fences, gates, etc . .)
    9. farm equipment
    10. lawn equipment
    11. valve automation
    12. truck repair
    13. truck customizers
    14. outdoor cooking (big down here)
    These are the ones I have come up with . . . any thing else or comments on the above would be appreciated . . .
    Thanks "WACKO" Steve
    Millermatic 251
    Lincoln AC/DC "Tombstone"
    Milwaulkee Grinder 4 1/2"
    Clark Grinder 4 1/2"
    CT.
    333
    Signs with backlit illumination.
    T.J.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    Oct 2006
    Mpls, MN
    1,790
    Build it rigid enough to handle a router - then you can do wood and plastic signs as well.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Apr 2008
    dallas,tx
    207
    Custom car audio shops, body shops that do custom work. Smaller places that may not need huge quantities. If you were in Dallas, I'd have plenty for you
    Mar 2009
    Toronto
    27
    Custom electronic project panels...
    Mar 2009
    NY
    103
    So are you making this from basic stamp / pic controller and stepper motors, I can't imagine that it would be all that difficult with a little work. The interface software might be the toughest part. I have been thinking about this also it seems the cost for these things are so excessive. This would be a great open source project, making a great tool for the builder that he or she could build.
    I just looked there is open CNC software already. I am going to have to look into this, thanks for the thought.
    http://sourceforge.net/projects/opencnc
    no files at opencnc
    http://www.linuxcnc.org/ this looks more promising.
    Oct 2007
    139
    Smile Mach 3
    Quote Originally Posted by nikodell View Post
    no files at opencnc
    Look @ Mach 3 Software . . .http://www.machsupport.com/
    Millermatic 251
    Aug 2006
    Raymore Missouri
    1,920
    Quote Originally Posted by Wacko Welder View Post
    1. motorcycle
    2. 4X4
    3. utility trailer
    4. small fab
    5. welding
    6. machine
    7. boat dealers
    9. farm equipment
    10. lawn equipment
    12. truck repair
    Do you know what you'll use to build it and what software? steppers/servos..
    rack and pinion or screw drive? I built one in 2006 that I have a router on now. Haven't used it with plasma yet. If you search for "cnc router" on this site you'll see some pics and info. I use Mach 3, Aspire 2 3D software.
    nick
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Mar 2009
    NY
    103
    hay Nick have you used your cnc router much? Got any feed back on what you built what works good what you might do different?
    Seems like you could adjust that easily for plasma, I am thinking of doing an initial smaller build for plasma, before seting up one as a cnc router, or possibly making one with a transforming base where I can do either plasma or wood and other materials. That would be best for space considerations. Not all that practical for other reasons, wood dust and sparks could create an issue if one were not extremely careful.
    I have done work with steppers and computers before and actually made my own controller boards. I am more concerned with making a gantry that is stable and accurate. I was wondering how yours is under load say in a hardwood, what kind of cuts can you make?
