Just need an opinion from all you guys . . .
My intention is to build or buy a CNC Plasma Cutter with a 4'X4' table. I want to operate it as a hobby machine for art / craft type of stuff. The reason for the small table, I can not imagine handling sheet larger, whether it be storage or getting on the table by myself . . . I'll be in a 2 car garage . . . :-)
My question to you guys is based on your experiences, where would you try to hustle additional work for my table.
I'm thinking, all types of shops;
1. motorcycle
2. 4X4
3. utility trailer
4. small fab
5. welding
6. machine
7. boat dealers
8. ornamental iron (fences, gates, etc . .)
9. farm equipment
10. lawn equipment
11. valve automation
12. truck repair
13. truck customizers
14. outdoor cooking (big down here)
These are the ones I have come up with . . . any thing else or comments on the above would be appreciated . . .
Thanks "WACKO" Steve![]()
Thread: CNC Plasma Cutter . . .
04-10-2009, 06:30 PM #1
Millermatic 251
Lincoln AC/DC "Tombstone"
Milwaulkee Grinder 4 1/2"
Clark Grinder 4 1/2"
04-10-2009, 09:23 PM #2
- Sep 2005
- CT.
- 332
Signs with backlit illumination.
T.J.Miller Dynasty 300DX
HTP MIG 240
HTP 380 Plasma
Bridgeport Milling Machine
South Bend Lathe
Etc. Etc....
tjsperformance.com
04-11-2009, 12:16 AM #3
Build it rigid enough to handle a router - then you can do wood and plastic signs as well.
Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
04-12-2009, 10:57 PM #4
Custom car audio shops, body shops that do custom work. Smaller places that may not need huge quantities. If you were in Dallas, I'd have plenty for you
04-13-2009, 07:27 AM #5
- Mar 2009
- Toronto
- 27
Custom electronic project panels...
04-13-2009, 08:18 AM #6
- Mar 2009
- NY
- 103
So are you making this from basic stamp / pic controller and stepper motors, I can't imagine that it would be all that difficult with a little work. The interface software might be the toughest part. I have been thinking about this also it seems the cost for these things are so excessive. This would be a great open source project, making a great tool for the builder that he or she could build.
I just looked there is open CNC software already. I am going to have to look into this, thanks for the thought.
http://sourceforge.net/projects/opencnc
no files at opencnc
http://www.linuxcnc.org/ this looks more promising.Last edited by nikodell; 04-13-2009 at 08:29 AM.
04-13-2009, 05:09 PM #7
Mach 3
Look @ Mach 3 Software . . .http://www.machsupport.com/
Millermatic 251
04-14-2009, 07:05 AM #8
Do you know what you'll use to build it and what software? steppers/servos..
rack and pinion or screw drive? I built one in 2006 that I have a router on now. Haven't used it with plasma yet. If you search for "cnc router" on this site you'll see some pics and info. I use Mach 3, Aspire 2 3D software.
nickLast edited by monte55; 04-14-2009 at 11:03 AM.
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
04-14-2009, 08:13 PM #9
- Mar 2009
- NY
- 103
hay Nick have you used your cnc router much? Got any feed back on what you built what works good what you might do different?
Seems like you could adjust that easily for plasma, I am thinking of doing an initial smaller build for plasma, before seting up one as a cnc router, or possibly making one with a transforming base where I can do either plasma or wood and other materials. That would be best for space considerations. Not all that practical for other reasons, wood dust and sparks could create an issue if one were not extremely careful.
I have done work with steppers and computers before and actually made my own controller boards. I am more concerned with making a gantry that is stable and accurate. I was wondering how yours is under load say in a hardwood, what kind of cuts can you make?
