Results 1 to 10 of 11
    Feb 2009
    117
    Default Dynasty 200DX and Millermatic 211 power pig tail.
    Please help, I have a Dynasty 200DX and Millermatic 211 both as you probably know both of them fly on 110V and 220V I need help with a pig tail for them both. The 211 came with a plug adapter that looks like a huge standard three prong 110V. Nothing at my place has a socket like it.
    So, if I just use a regular 110V plug on the end of the main wire from the machine and then make a pig tail that has the female for the 110V at one end and a 220V plug at the other, it should work. The two hot lines go back into the 110V plug and the machine takes care of the rest. Am I correct. Thanks for any help given.
    Cheers,
    James.
    Appleton, WI
    419
    Changing the plug adapter on the end of the cord on the Millermatic 211 is what links the primary on the machine to the correct voltage. If you have the 110 volt plug on the end of the Millwermatic 211's power cord and apply 230 volts to it you will damage the unit.
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
    Nov 2006
    Lake of the Ozarks MO
    3,594
    Quote Originally Posted by Miller Kevin View Post
    Would you care to elaborate on that a bit??
    I really wonder how you could screw that up?
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Appleton, WI
    419
    Fusion,
    Well it happens just like James was asking if he could do.
    James question: "So, if I just use a regular 110V plug on the end of the main wire from the machine and then make a pig tail that has the female for the 110V at one end and a 220V plug at the other, it should work"?
    Having the 110 volt plug on the end of the power cord links the unit for 110 volts. Then you take an extension cord and put a 110 volt recepticle on one end and plug the machine into it, on the other end of the extension cord you put a 230 plug and plug it into a 230 volt recepticle on the wall. *DO NOT DO THIS* it is not good for the fan motor, the control transformer or the main control board.
    Kevin Schuh
    Service Technician
    Oct 2008
    Oregon
    193
    The 211 comes with a 15 Amp 110 volt adapter and a 50 Amp 220 volt adapter, there is also a 20 Amp 110 volt adapter available for it.
    They are keyed to fit the Miller welder power cord (MVP).
    If you need to use an extension cord, size it according to which adapter you are using (15Amp, 20Amp, for 100 Volt and I just bought a 25 ft 8 Guage extension cord for the 220 volt adapter.
    I can't tell by looking at the Dynasty, what kind of end is on the power cable but don't try to bypass the design and end up destroying something.
    If you need a 20 Amp 110 Volt circuit, try to get someone to help you install one, if you don't know how to do it yourself.
    I wired 15 Amp, 20 Amp receptacles for my 110 volt welder and use NEMA 6-50R receptacle for the 220 volt, with a 40 Amp circuit breaker. I still hear some confusion on the correct size of breaker to use for the 211.
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
    Sep 2002
    Clark County, NV
    2,696
    Quote Originally Posted by jmpgino View Post
    ...The 211 came with a plug adapter that looks like a huge standard three prong 110V.....
    That's a NEMA 6-50 and it's 240V only, up to 50A amps continuous.
    Los Angeles
    2,955
    http://www.millerwelds.com/resources...ad.php?t=17065
    he ain't answered his other post- maybe he blowed hisself up
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Los Angeles
    2,955
    Quote Originally Posted by ligito View Post
    What does the manual state?
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
    Oct 2008
    Oregon
    193
    It's too ambiguous for me to tell.
    Milwaukee Hole Hawg
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    1997 Suzuki DR650
    Los Angeles
    2,955
    The manual states the MAX breaker to use when using the Minimum sized wire for a dedicated Welder receptacle.
    If you want to wire up a 40amp Circuit or use it on a 40amp circuit no problem but you have to use the correct wire to match the 40amp CB.
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
