Results 1 to 9 of 9
    Aug 2004
    Milan Michigan
    1,836
    Default Crane system that I just finished.
    Here are some pictures of a crane system that I designed, fabricated and erected.
    This system is for a company that builds gear boxes and transmissions for for the military vehicles.
    This is a loopng crane that has 10 hoists on it so I had to do the buss duct to supply power to all the cranes so they can just keep running around the ovals and not worry about tangled chords.
    The steel work was pretty easy but modifying the trolleys to hold what they call the collector took me a bit of research and then rolling the 3 lines of duct bar all at a different radiouse took some time.
    I'm very happy with the way it all turned out.
    Aug 2004
    Milan Michigan
    1,836
    Here are more pictures my computer quit so I had to reboot it.
    I forgot to mention exactly what this is for.
    Its an assembly line and they will have approx. 6 stations.
    Dec 2008
    Arizona
    812
    Thumbs up
    Quote Originally Posted by Portable Welder View Post
    You should be! Very impressive!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Mar 2009
    central ohio
    16
    I've learned the more time you plan out a job even the assembly steps,the job comes out great.Also,you'll have no rework!Beautiful ironwork!
    Nov 2006
    Lake of the Ozarks MO
    3,594
    I can't help but ask... could you please post up some pics of your bender?
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Aug 2004
    Milan Michigan
    1,836
    Here are some pics of the roller we built this winter.
    The rollers are made out of 3" diameter dom tube that is 1/2" wall thickness.
    Its not one of those things you use every day but when you need it you need it.
    By the way, The rolled I- Beam was not done with this roller but the rolling of the electrical figure 8 duct bar was.
    Feb 2009
    Island Falls Maine
    562
    looks like that will work good. Nice work.
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Very interesting project, it looks like it turned out great!
    at home:
    2007 302 Trailblazer with the Robin FOR SALE
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Aug 2004
    Milan Michigan
    1,836
    I'm pretty happy with this project, The only part that I did not do was the little breaker box that mounts to my trolley and wiring the collectors to the little breaker box.
    After this project I'm thinking that I should advertise in the phone book under cranes.
    Just not sure what type of certifications that are needed to be a crane builder.
    I did this system without engineered drawings due to its size.
    The structure was a little over built to give a safety factor, I'm sure it will handle 3 times the weight that all ten cranes can lift together.
    As far as electrical goes my master electrician will cover that.
    So any way what does it take to be a certified crane inspector.
