Please help, I have a Dynasty 200DX and Millermatic 211 both as you probably know both of them fly on 110V and 220V I need help with a pig tail for them both. The 211 came with a plug adapter that looks like a huge standard three prong 110V. Nothing at my place has a socket like it.
So, if I just use a regular 110V plug on the end of the main wire from the machine and then make a pig tail that has the female for the 110V at one end and a 220V plug at the other, it should work. The two hot lines go back into the 110V plug and the machine takes care of the rest. Am I correct. Thanks for any help given.
Cheers,
James.
Results 1 to 10 of 11
04-10-2009, 09:39 AM #1
- Feb 2009
- 93
Dynasty 200DX and Millermatic 211 power pig tail.
04-13-2009, 11:14 AM #2
Changing the plug adapter on the end of the cord on the Millermatic 211 is what links the primary on the machine to the correct voltage. If you have the 110 volt plug on the end of the Millwermatic 211's power cord and apply 230 volts to it you will damage the unit.
Kevin Schuh
Service Technician
Miller Electric Mfg. Co.
04-13-2009, 12:18 PM #3
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
04-13-2009, 01:27 PM #4
Fusion,
Well it happens just like James was asking if he could do.
James question: "So, if I just use a regular 110V plug on the end of the main wire from the machine and then make a pig tail that has the female for the 110V at one end and a 220V plug at the other, it should work"?
Having the 110 volt plug on the end of the power cord links the unit for 110 volts. Then you take an extension cord and put a 110 volt recepticle on one end and plug the machine into it, on the other end of the extension cord you put a 230 plug and plug it into a 230 volt recepticle on the wall. *DO NOT DO THIS* it is not good for the fan motor, the control transformer or the main control board.Kevin Schuh
Service Technician
04-13-2009, 06:11 PM #5
- Oct 2008
- Oregon
- 193
The 211 comes with a 15 Amp 110 volt adapter and a 50 Amp 220 volt adapter, there is also a 20 Amp 110 volt adapter available for it.
They are keyed to fit the Miller welder power cord (MVP).
If you need to use an extension cord, size it according to which adapter you are using (15Amp, 20Amp, for 100 Volt and I just bought a 25 ft 8 Guage extension cord for the 220 volt adapter.
I can't tell by looking at the Dynasty, what kind of end is on the power cable but don't try to bypass the design and end up destroying something.
If you need a 20 Amp 110 Volt circuit, try to get someone to help you install one, if you don't know how to do it yourself.
I wired 15 Amp, 20 Amp receptacles for my 110 volt welder and use NEMA 6-50R receptacle for the 220 volt, with a 40 Amp circuit breaker. I still hear some confusion on the correct size of breaker to use for the 211.Last edited by ligito; 04-13-2009 at 06:32 PM.
Millermatic 211 AutoSet w/MVP
Century 110 volt 90/110 MIG-Gone to my son, in Texas
Victor SuperRange OA
Milwaukee Cold Cut Saw
Milwaukee Portable Deep Cut Bandsaw
Milwaukee Hole Hawg
Jet Horizontal/Vertical Bandsaw
Jet MD-18 Mill Drill
Orbit Drill Press
12 Ton Floor Press
2002 E-350 V-10:
1983 F-150 4.9L 6
2004 Honda ST1300
2007 Suzuki LTA400F Quad
1997 Suzuki DR650
04-14-2009, 01:41 PM #6
- Sep 2002
- Clark County, NV
- 2,696
04-14-2009, 02:28 PM #7
http://www.millerwelds.com/resources...ad.php?t=17065
he ain't answered his other post- maybe he blowed hisself up
04-14-2009, 02:29 PM #8
04-14-2009, 02:46 PM #9
- Oct 2008
- Oregon
- 193
It's too ambiguous for me to tell.
Milwaukee Hole Hawg
Orbit Drill Press
12 Ton Floor Press
2002 E-350 V-10:
1983 F-150 4.9L 6
2004 Honda ST1300
1997 Suzuki DR650
04-20-2009, 04:58 PM #10
