Results 1 to 7 of 7
Thread: miller 35
    19
    Default miller 35
    anyone have luck finding miller 35 consumables on the web ?
    3,953
    http://www.usaweld.com has anything you need for your gun....Bob
    Smile welcome to the board
    the MM 35 uses a GA-20C gun,( if its original equipment) its tips are the same as the M-25 gun. so you could get tips anywhere they sell the miller tips just ask for tips for a M-25 gun if they don't know what tips you need.
    just about any place that sells tips should be able to sell them to ya.
    Sep 2007
    NE Ohio
    44
    The GA-20C gun is different than the M-25, the nozzles screw on. I just went through this with my MM200. USA Weld doesn't have anything for the GA-20C, they show it on their website but I called and they said that they just haven't removed it yet.
    I emailed Miller and they said that they have everything in stock and to order from a dealer.
    David
    do you have the part #'s ?? my book said it was the same tip's ?? strange?? it is an older book but i would think some thing like that would not change??? thanks for the heads up.
    Sep 2007
    NE Ohio
    44
    fun4now,
    You are correct, the tips are the same. Everything else is different, nozzles and tip adaptors. I just bought a like new MM200 that the nozzle had been damaged somehow and went to the USA Weld HTP looking for nozzles. As stated they have dropped that line.
    With my welder I got several extra tips. Half of them were about 3/8" longer than the standard tips for more stickout I guess. Interesting.
    David
    Tip's are really about the only thing i consider as a consumable for the MIG gun so i just checked them. my bad i could look at other parts if needed. i have had my MIG over 6 years and only replaced tips, so thats what i looked at. should have looked at a few other pieces i suspect to give a fuller answer.
    thanks for the help in pointing that change out.
