    banning ca.
    135
    Question thermal arc. Pak 3 cutting system???
    I had a friend bring me a thermal arc. Pak 3 cutting system today he didn't know anything about it and i've never used one myself ether . anyone know about um or have one
    here's the info I could see on it
    thermal dynamics corp.
    modal - Pak3
    sn# - t40515a18241e
    volts - 220
    ph - 1
    amps - 20
    secondary rated current - 28 amps
    open circuit voltage - 275 volts
    40% duty cycle
    banning ca.
    135
    noone has any info on this pak3???
    Mar 2009
    Hazelwood Mo USA
    462
    I have a pak 50 system, it is a 1/2" machine, dont know anything about a pak 3. I had one earlier that I traded in, it was a 1/4" max machine and wasnt big enough, dont remember what it was called, it was a Thermal Dynamics machine as well.
    mike sr
    banning ca.
    135
    someone told me today that the pak3 was a 5/16'' max cut
