Results 1 to 10 of 15
    Nov 2008
    Roy, UT
    79
    Default control arm tube insert welds
    here are a few pics of the tube inserts I was having trouble with the threads gauding.....I used the anti splatter spray on em' & it worked like a champ!
    \\fshill\users$\d\Derek.Allen\Documents
    Nov 2008
    Roy, UT
    79
    O! tig welds were done with my Maxstar 200 STR 1/16" root let it fully cool & then a 1/8" cap. As you can see some of the welds aren't capped yet----ran out of Argon
    Jan 2007
    Midland, Mi.
    313
    Nice welds!
    Why did you make the arms adjustable?
    Aug 2006
    near rochester NY
    9,881
    great looking welds. what are you making ? do we get a full pic of the complete toy ??
    don't ya hate it when you run out of argon in the middle of something.
    i got a backup 80 tank to help keep that from happening. when my big tank is getting close to empty i pull it off and use the 80. this way if the 80 runs out be for i go for a refill there is still a little left in the big one.
    although probably not enough to do all the caps.
    Nov 2008
    Roy, UT
    79
    Adjustable control arms just sounds better I guess? , I will take more pics along the way & post them up.
    Dave---not to bad for a "stick" machine hugh? Thanks for all your help BTW getting me all set up to tig on the STR!
    Nov 2008
    Roy, UT
    79
    I am building a 4-link rear & 3-link front coilover suspension on a 79' scout.
    Jan 2009
    Gold Hill, NC
    51
    Nice work!
    Feb 2009
    202
    anytime i do a weld like that i use "never seize" or some call it "anti seize"......nice work i have a 1972 scout i'm going to do a spring over axle conversion....
    Sep 2007
    NE Ohio
    44
    The weld shrinking compresses the outer thread. After welding run a tap through it.
    David
    Dec 2008
    Arizona
    812
    I had the same problem when I did some on my tie rod and steering link. Ran a tap through them when I was done welding.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
