Results 1 to 10 of 15
    Nov 2008
    Roy, UT
    79
    Default control arm tube insert welds
    here are a few pics of the tube inserts I was having trouble with the threads gauding.....I used the anti splatter spray on em' & it worked like a champ!
    \\fshill\users$\d\Derek.Allen\Documents
    Nov 2008
    Roy, UT
    79
    O! tig welds were done with my Maxstar 200 STR 1/16" root let it fully cool & then a 1/8" cap. As you can see some of the welds aren't capped yet----ran out of Argon
    Midland, Mi.
    313
    Nice welds!
    Why did you make the arms adjustable?
    great looking welds. what are you making ? do we get a full pic of the complete toy ??
    don't ya hate it when you run out of argon in the middle of something.
    i got a backup 80 tank to help keep that from happening. when my big tank is getting close to empty i pull it off and use the 80. this way if the 80 runs out be for i go for a refill there is still a little left in the big one.
    although probably not enough to do all the caps.
    Nov 2008
    Roy, UT
    79
    Adjustable control arms just sounds better I guess? , I will take more pics along the way & post them up.
    Dave---not to bad for a "stick" machine hugh? Thanks for all your help BTW getting me all set up to tig on the STR!
    Nov 2008
    Roy, UT
    79
    I am building a 4-link rear & 3-link front coilover suspension on a 79' scout.
    Jan 2009
    Gold Hill, NC
    51
    Nice work!
    199
    anytime i do a weld like that i use "never seize" or some call it "anti seize"......nice work i have a 1972 scout i'm going to do a spring over axle conversion....
    Sep 2007
    NE Ohio
    44
    The weld shrinking compresses the outer thread. After welding run a tap through it.
    David
    Dec 2008
    Arizona
    801
    I had the same problem when I did some on my tie rod and steering link. Ran a tap through them when I was done welding.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
