Results 11 to 14 of 14
    Honolulu, HI
    103
    Nice welds. My dad used to gas weld everything. I wish I paid more attention to the stuff when he was still alive Unfortunately, I didn't get into it again until my mom asked me to clean out his workshop last year.
    Ocean City, Maryland
    951
    Wow nice welds, I too have brazed alot yrs ago. but now it seems, with a plasma cutter, TIG and MIG, I don't use the torch for much except heating things, same with stick, just sits there mostly. Like Dabar, I am interested in it so anything you've made I'd like to see. Also any info is appreciated.
    Scott
    HMW [Heavy Metal welding]
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by 6010 View Post
    I found this site with information on rods. It may be of interest to someone.
    They also have some videos of repair work.
    WWW.muggyweld.com
    I have to warn you, that stuff isnt "welding" at all, its more like a low temp braze. The cored rods are also actually brazing rod. The drawback is that the brazing is not ductile at all, and is designed to be used with surface area I.E. a lap joint. Butt welds with brazing material arent that reliable and unfortunately the entrie area has to be removed to re-do a braze as the material infects the parent metal at welding temp.
    I use either Allstates aluminum welding flux, or the flux sold by Kent at www.tinmantech.com. He also is a good source of learning material. Use a good spring water like evian with the flux.
    You can use pretty much any torch you want, heck ive even used a cutting torch on castings! OH and OA can both be used with great results. If anyone has any specific questions feel free to e-mail me anovak@mercmarine.com
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Jul 2007
    Batavia, NY
    159
    Quote Originally Posted by makoman1860 View Post
    -Aaron
    Correct on the brazing/welding info posted above. Basically with O/A welding whether steel or aluminum you actually get the parent material to a molten state (puddle). With brazing the only thing that melts is the filler.
    The Allstate flux you use is pretty much the same as the old Oxweld Alumaflux I believe. Oxweld was a trademark of Linde...then L-tec...then Esab. And then Esab bought Allstate. You can't tell the players without a program..
    Aaron, again nice work...that's old school stuff bro!
    Rich Ferguson
    Sales Technician
    Jackson Welding Supply Co.
    www.jacksonweldingsupply.com
