Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Bandsaw
  1. #21
    May 2006
    176
    I would stay away from the HF saw and its ilk just because of the difficulty I've had trying to fine-tune the adjustments on my Enco (Tiawan) 4x6 saw. I can get a 90 degree cut ok, but it has been difficult to maintain the accuracy of the cut in three dimensions. That is, the blade guides are hard to set so that the blade drops straight down producing a true 90 degree down cut. I had to re-machine the keyed guide adjusters for the roller guides and still it's difficult.
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
  2. #22
    Jul 2007
    Carroll County, Maryland
    108
    Quote Originally Posted by crawdaddy View Post
    Anyone know of a good metal bandsaw,that doesnt take up too much space? will be used once a month or so but still want decent quality hoping to stay under $500 hundred range if possible.Is vertical or horizontal better for hobby use?Ive never used one so I dont have a clue.Mike
    crawdaddy, here's a portable with stand for $150. Probably will meet your needs.
    http://grizzlyindustrial.com/product...-w-Stand/G8692
    The definition of courage. "It's when you know you're licked before you begin, but you begin anyway and you see it through to the end no matter what." From "To Kill a Mockingbird"
  3. #23
    Nov 2008
    26
    I've got a Delt vert/horz w/ a 1hp (120V) and its a good saw. Its a dry saw type saw, meaning no available or place for a coolant/mist system. It still a good saw though, especially after I put a Starrett blade on there
    I got it off ebay for $240 too...normally it sells for $600-750, but there are a few on ebay every once in a while.
  4. #24
    There is no doubt that the HF H/V bandsaw produces less than perfectly square cuts. However I have had little trouble getting close enough for welding purposes. If you need machine shop quality of cut, then you need machine shop quality machines. For the money, even with mods, I think my little HF bandsaw is an asset to my shop. With it I can make cuts quietly on Sunday mornings (not disturbing the neighbors, with out all the sparks and dust, and the parts are always cool enough to pick up immediately after the cut as long as I use the coolant pump.
    Larry
    "I feel for the man who can only spell a word one way"......Mark Twain
    Lincoln AC225-S (OLD/Copper Wound)
    Lincoln Weldpac 100
    Miller Matic 180 (auto set)
    Miller Spool gun 100
    Miller Spectrum 375 Extreme
    Victor Super Range II
  5. #25
    Nov 2008
    26
    Quote Originally Posted by Larwyn View Post
    Is that a little DIY coolant system?? Looks good, I bet it wouldn't be too hard, maybe a little 1/3hp pump, lines, recovery pan, etc...
    Bandsaw > chop saws
    I just picked up a Ridgid chop last week, its very loud, messy, fire hazard, but it gets certain jobs done
  6. #26
    That is a pretty slick setup Larwyn.
  7. #27
    2,641
    Quote Originally Posted by nikodell View Post
    Could be but they are psychically different in the photos.
    uh what?
  8. #28
    Lake of the Ozarks MO
    3,447
    uh what?
    IOW you can tell by looking they are not the same motors. Even tho jet is probably the only one telling the truth about HP
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
  9. #29
    2,641
    Went over yer head
  10. #30
    Broccoli,
    If you check the pic of my bandsaw above, you will notice that I have used your tip of using the vice grip style drill press clamp on the saw. That's a great idea that works out really well for cutting small parts at odd angles (or square for that matter. I still do use the original vise at times but the dp clamp sees a lot of use. Thanks for a great hint!!!
    Larry
    Lincoln Weldpac 100
