Results 1 to 7 of 7
    Blissfield, MI
    78
    Default Weld table and super log splitter!
    Been almost a year since I have been on here. Have a couple projects I did this winter. I made a log splitter out of 12"x45x15' I-beam with a 5" bore X 48"
    Stroke cylinder. Push plate is 1 1/4" X 18" square with 5/16" dowel pins for grip. All mounted upside down for no touch log splitting in the comport of the cockpit of my Bobcat. I still have to get painted but have not done do since I'm going to add some extra steel on the wedge for a 6 way split.
    Just put together a weld table that has a 5'X10'X1" plate. 3"X3"X7ga. sq. tube for legs. I added racks for clamps, receiver hitch type sockets on all 4 corners for what ever things you would want to add. At the moment I have a vice and a 10' piece of 3"X1/4" angle for welding round stock. Have not painted yet but am going to try selling these. Would also like to look into getting top surface ground. Anyone know how much that would cost?
    Modern Metalworking L.L.C
    Blissfiled, MI
    517-605-9481
    Miller Dynasty 350 Tig runner
    Hobart 3-phase mig
    Hypertherm 1000 plasma
    Mill
    Lathe
    Box break
    Shear
    Mar 2009
    234
    Very nice. Any idea on the table's weight?
    Oahu, Hawaii
    2,469
    Wow!!! Nice job on that table
    I'm not late...
    I'm just on Hawaiian Time
    Blissfield, MI
    78
    Top is 2000 and a couple hundred on the legs. Should come in just under 2500lbs.
    Blissfiled, MI
    517-605-9481
    Hobart 3-phase mig
    Mill
    Lathe
    Box break
    Shear
    Mar 2008
    Battle Ground WA
    179
    Nice table!!
    I am looking into putting similiar leveling feet on my table, mind I ask what size stem and manufacture? Surely yours shouldn't warp much nor move around!!
    Tim---I think my table would sit on the shelf of yours!
    Retired Elevator Consrtructor Local 19 IUEC
    AK bush pilot (no longer in AK) too old and no longer bold)
    Chaplain CMA chapter 26
    Dynasty200dx (new and loving it)
    MM-252 (NEW AND LEARNING IT)
    Hypertherm PM-45
    Miller 140 mig 110v
    Vtwin builder
    Blissfield, MI
    78
    Bought out of Grainger, don't have manufacture info right now, I'm at work. They were 3/4"-10 bolt size. I bought the female pads and were $25 a piece.
    Blissfiled, MI
    517-605-9481
    Hobart 3-phase mig
    Mill
    Lathe
    Box break
    Shear
    Mar 2008
    Battle Ground WA
    179
    Thanks, I will look into them at Graingers. As well I have seen some (don't know their capacity) available from Industrial Caster?
    Are you offering free shipping?? (LOL)
    Tim
    Hypertherm PM-45
    Miller 140 mig 110v
    Vtwin builder
