Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: a fishmouth?
    arkansas
    781
    Default a fishmouth?
    anybody know where to find a pipe notcher that is very portable? i have been doing a lot of hand rails lately and i am tired of notching pipe with a grinder. i have seen the one that uses a hole saw, but it doesnt clamp to the pipe to use a hand drill instead of a drill press. or if anybody has a better idea, please....
    welder_one
    www.sicfabrications.com
    Oahu, Hawaii
    2,469
    Try this one, I know it's very popular!
    http://www.lowbucktools.com/notcher.html
    Also, try google "pipe notcher" (with the quotes) and you'll have a lot to choose from!
    I'm not late...
    I'm just on Hawaiian Time
    Oct 2005
    Bulverde, Tx
    1,244
    I just use my saw. I can cut a full fishmouth in about 20 seconds. This one is 1 1/4 sch 40 pipe cut 30 on each side to make the joint. They fill up nicely and hold very well.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Oahu, Hawaii
    2,469
    DDA52,
    My classmate says an old timer does that at his shop...SHOWOFF!!!
    Put it in the saw, how do you keep it from walking?/slipping??
    I'm not late...
    Oct 2005
    Bulverde, Tx
    1,244
    Bert, I primarily do it with my DeWalt Multicutter. The clamp holds it just fine. I have a few walk a little, but not enough to really mess up the cut....or the blade.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    Oahu, Hawaii
    2,469
    DDA52,
    oh, I heard of some guys on this forum have the DeWalt mulitcutter, it's a dang chopsaw!!! I was thinking of the sears multicutter that is handheld, and has 2 blades supposedly running opposite each other. Why do they call yours multicutter?
    thanks in advance
    I'm not late...
    Raymore Missouri
    1,920
    They cut more than one material.....
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Ocean City, Maryland
    951
    Thumbs up
    Quote Originally Posted by welder_one View Post
    I use this one http://www.northerntool.com/webapp/w...atchallpartial
    I use it in a vise with a 1/2" milwaukee hole shooter. Harbor frieght has one too and it seems to be just like the more expensive one. I have both. http://search.harborfreight.com/cpis...eyword=notcher
    I guess if you had 100s of notches to make this might be too slow, but I've used them alot. Buy good hole saws and use lubricant, they last a long time. Just buy a hole saw with close dimensions of the outside of the pipe At least I've had good luck. Makes a very nice fishmouth. even has angles on it so you cna cut a 45 or angles. I guees you could clap the pipe in something then clamp this to the pipe
    Thats really cool cutting them out with a saw, does it really fit that good on the sides? I have never tried it.
    Scott
    HMW [Heavy Metal welding]
    Oahu, Hawaii
    2,469
    I'll try that with my steelmax chopsaw! Should work fine!!!!
    thanks guys!!!
    I'm not late...
    i have seen this one in action http://www.lowbucktools.com/notcher.html its quick and simple. add a good leverage bar and you are good to go, no power or drills needed. would be easy to mount to the truck or a hitch mount.
