Results 11 to 20 of 27
    Jun 2007
    Camden, SC
    156
    My only other suggestion for your "popping" sound, and Rich-The-Jackson-Rep will be able to answer this a little better, is: are you sure you've got good quality tungsten? I recently picked up a couple of sticks of 2% Thoriated from my LWS that wasn't in very good shape....have you swapped out tungsten or considered going back to your LWS and getting some new stuff?
    Also...how are you grinding your tungsten (sharpening it)? Is it possible that you're contaminating it on your grinding wheel?
    Clint Baxley
    Baxley Welding Service
    Rembert, SC 29128
    New Jersey
    5
    the tungsten is 2% thor......(however you spell it) red, argon set at 20cfh, the electrode is approx 1/8"-3/8" away from the work piece, the tungsten is sharpened to a pencil like point on a gringing wheel i have that is only used for the tungsten. i believe it is my ground, i grinded and stripped away the paint on the frame rail of my car for the ground. i noticed this yesterday when practicing on scrap, clamped ground right to work piece no issues with arc. i know its just going to take alot of practice. should i use a bigger cup to help cool more of the material??? or stick with the 1/4-3'8" cup i am currently using. thanks
    132
    I do a bunch of short welds on square aluminum tubing coming together at all sorts of angles.
    I get popping because of turbulent gas flow I think. At the edge of the tubing I'm trying to shove the filler in, the arc burns off my filler too soon and it'll keep popping as long as I try to put it in. I have to then change angles.
    -James
    Jun 2007
    Camden, SC
    156
    Default Let's Try This
    Quote Originally Posted by nails79 View Post
    In GTAW welding, shielding gas doesn't really "cool" the weld puddle...all it's for is shielding the molten puddle from external and internal contaminants. I'm sure there's a miniscule amount of "cooling" that takes place, but that's not the point.
    I'm sorry I'm forgetting this as I type, but what type of power-source are you using again? Is it an inverter-based power source or simply a square-wave capable transformer based supply?
    Try this and see what happens: grind your tungsten all the way down to a needle-sharp point. Make sure your ground is good...preferably on your firewall as I think the frame may be a little far away and requires the current to travel to the firewall via numerous screws/bolts of varying metallic qualities. Switch up to a 1/2" cup size (about a size 6...which is actually a hair larger than 1/2" I believe). Allow the tungsten to stick out of the end of the cup approximately 1/2". Lay the cup over on it's side on the firewall and adjust your angle so that your tungsten tip is NO MORE THAN 1/16" - 1/8" away from where you're attempting to create your puddle. If you can, pay attention to where, EXACTLY, your arc is contacting the firewall as it comes off of the tungsten. Don't attempt to start your puddle RIGHT on the edge of the hole(s)....since you're filling them in, you should probably start your puddle about 1/4" away from the edge of the hole, add a globule of filler metal, and then--backing off the pedal/amptrol as necessary but keeping the puddle molten--work the molten puddle into and around the hole. Keep in mind that this is where everyone is talking about the benefits of having a copper backing plate: it gives something for your molten puddle to flow into/across without having to worry about the puddle sticking to the backing plate.
    Enplck (welding educator) and SundownIII and Aeroweld (and BlackWolf, wherever the heck he is) are much better at this sort of thing than I am and I wish to G_d they'd jump in with their .02 cents...I'm afraid I'm going to start confusing you if I keep going.
    Is any of this making any sense to you? Let me know how it's going or if I can clarify anything I've said so far.
    ~Clint
    Clint Baxley
    Rembert, SC 29128
    Jun 2007
    Camden, SC
    156
    Thumbs up Super-Heated Gas Has To Have SOMEWHERE To Go...
    Quote Originally Posted by jamscal View Post
    -James
    James, I doubt your popping has as much to do with turbulent shielding gas flow as it does with air/gas resistance flowing through your square tubing and then "blowing up" or "blowing back" into your puddle and onto your tungsten as you weld your seams closed.
    Either try back-gassing your tube (if ultra-clean looks are important) or try drilling a super-small hole somewhere along the tubing to let super-heated air and gas expand/escape as you're closing in your welds.
    One of the aerospace guys on here probably has something else that will work but that's a common problem for me when TIG'ing on aluminum tubes in rails or towers or sponsons on boats.
    ~Clint
    Clint Baxley
    Rembert, SC 29128
    Deltaville, VA
    2,241
    Nails,
    You've gotten some good advice here. Know it's all a lot to absorb at one time. I'll try to summarize and then make a couple of recommendations.
    Tungsten-2% Thoriated is good.
    Cup size is fine.
    20 CFH Argon gas flow is fine.
    18-22 ga material-challenging for experienced/intimidating for beginner.
    Copper spoon/backing plate almost essential.
    1/2" hole-about as big as you want to tackle.
    Get good ground as close as possible to work.
    Start with clean, reground tungsten. Popping, I suspect, is coming from a contaminated tungsten.
    As Clint suggested, start your puddle off the edge of the hole. Use your filler to control the puddle (.035 Mig wire works well). Move in a circular motion around the hole adding filler almost continuiously to keep the heat down. The more filler you can get in the more "heat sink" you create. Move pretty quickly til hole is filled. If that's not working for you, try doing short runs and stop. That will let the weld cool.
    The one thing I didn't see listed was whether you are using a remote control for your amps (footpedal or fingertip control). This would make your life a lot easier. You can then get your puddle started and then back off on the amps as heat builds in the weld. Without it you have to control the puddle with filler or by stopping the weld and allowing it to "freeze".
    Hope this helps some. Practice, Practice, Practice.
    132
    Quote Originally Posted by BWS29128 View Post
    ~Clint
    None of the tubes are being welded closed. I could be wrong as to the cause, but I still think it's turbulance and perhaps a bit of tungsten touching
    Nothing is in a good position, plus I'm putting 16 ga formed channel to 1/8" wall tubing of different sizes together in just about every joint configuration. And it has to be fast. I set it on 160 amps and pedal lower when necessary. But on the plus side they're not interested in appearance except they want small welds and don't want to deal with aluminum mig soot and splatter. Everything is getting powder coated.
    They're getting pretty welds for all that though. I'm using this place for practice.
    -James
    New Jersey
    5
    thanks for the replys guys, i am using a synchrowave 200 which i believe has the square wave technology. i am having better luck today, switched to a 1/16" 2% tungsten with a 1/2" cup, and i am using .040" filler rod and i am now seeing the puddle better. on the 22 gauge i have the amps set at 24, and on the 18 gauge i have the amps set at 34, i am using a foot pedal and i am by my self so not sure what the actual amps are im getting to. i have had the argon set at 20cfh all day with no problems, then all of a sudden the arc was very erratic and backed up into the cup and rounded my tungsten what causes this??? thanks
    Jun 2007
    Camden, SC
    156
    I'm not sure about your Amperage settings, so we'll have to wait for SundownIII to comment on that (or you can send him a PM...he always answers mine when he has time), and he's EXTREMELY familiar with the Synchro200, so that will help even more (my only Synchro experience was with a Synchro351 @ 440V and that was over 8 years ago). Whatever you're setting your Amps at is pretty close to what you're getting with the pedal-to-the-metal, as it were. Maybe you could have a friend watch your ammeter while you're welding? My Mom stopped by my shop one day while I was struggling with a particularly nasty piece of aluminum and I asked her to watch for me....not pretty, but there it is.
    Your comment about "all of a sudden the arc was very erratic and backed up into the cup" leads me to believe that you "sucked up" a piece of your weld puddle and contaminated your tungsten. There's nothing you can do in cases like this except stop, change or regrind your tungsten, and start again.
    I like SundownIII's suggestion for using .035 MIG wire if you have some....it's saved my butt a couple of times on thinner stuff and it was his suggestion that brought it to my attention about 5 or 6 months ago on a different board.
    Yes, your Synchro has square-wave technology, and one of the best in the business from what I've heard...far superior to my Lincoln PrecisionTIG 185.
    If "seeing the puddle" is a problem you're having and it's actually a case of you PHYSICALLY not seeing the puddle, then maybe we need to put you in touch with Jeff Noland at HTP to see about ordering you a Pyrex (clear) cup kit for your TIG torch. Jeff (the owner of HTP, I might add) will be the first to tell you (as he has/did with me) that Pyrex cups are NOT for every-day use, but on those occasions when you just have that weird angle that doesn't allow you to physically "see" your puddle because of the cup or other obstructions, it is ABSOLUTELY the way to go. If you're having trouble getting your puddle started, then we need to go back to what SundownIII was saying and play with your settings 'til you get it right.
    And don't worry: he preaches at me to "Practice Practice Practice" all the time
    Clint Baxley
    Rembert, SC 29128
    Jun 2007
    Camden, SC
    156
    Thumbs up
    PS: the Pyrex cup kits average about $30...not bad for the benefit it gives you.
    PPS: I'm sort of surprised that SundownIII hasn't suggested Lanthanated or Ceriated tungsten to you yet....he's a pretty big proponent of both of them and has turned me on to Lanthanated here recently for overhead TIG'ing on aluminum.
    Clint Baxley
    Rembert, SC 29128
