Results 1 to 10 of 15
    Seattle,WA
    55
    Default Which plasma cutter to buy?
    I was wondering if anyone had any suggestions for a plasma cutter to buy? At out shop we would use it mostly to burn holes in 3/8 tubular steel pipe. Doesn't have to be top of the line, but I still want something quality. thanks
    Welders do it hotter!!
    www.Munsonworks.com
    Wartburg,Tn
    575
    I would problly get the miller sperturm 625,my cuz has one it cuts good , I don`t know if it is rated 3/8 though let me check
    Inferno Forge
    Chris
    Wartburg,Tn
    575
    ok I checked and the 625 is rated to cut up to 5/8 serve
    Inferno Forge
    Chris
    Vero Beach, fl.
    761
    Default Which Plasma?
    What's your budget? How often will it get used?
    I'm thinking about the Spectrum 625 in the near future for my shop, sounds like it would do what you need it to do also. Dave
    Wartburg,Tn
    575
    opps forgot to ask a bout the budget
    Inferno Forge
    Chris
    Jul 2007
    Batavia, NY
    159
    Is 3/8" the thickest steel you will be cutting? Are you going to want to cut aluminum? Stainless Steel? If so what thickness'? Also how often are you going to be doing that maximum thickness?
    The way plasma systems are rated today can cause some confusion. In example lets take the Hypertherm Power Max 600. This machine has an adjustable output of 20-40 amps. It has the following capacities: Recommended Capacaity: 1/2" mild steel, Maximum Capacity: 5/8" mild steel, Severence Capacity: 7/8" mild steel (deduct aprox 10% for non-ferous metals). What I tell customers is if you are planning on cutting the maximum capacity 35% of the time or more you should go up one size unit. The real advantage's of plasma are quality and speed of cut (when talking about mild steel). The other obvious advantage is being able to cut non-ferous metals. Plasma units can be expensive to feed. While most manufacturers have done a real good job on making tips and electrodes last, they can be expensive to buy.
    So whether you buy a Miller, Hypertherm, Thermal Dynamics or what ever pay attention to how they rate their machines on thickness and cutting speeds at those thickness'. One other bit of advice if I could. Do yourself a favor and get a good inline air filter for you plasma system, they like clean dry air.
    One last word of advice...and this is just MY HUMBLE OPPINION....stay away from Esab plasma
    Rich Ferguson
    Sales Technician
    Jackson Welding Supply Co.
    www.jacksonweldingsupply.com
    Ocean City, Maryland
    951
    At work we have a Thermal dynamics cutmaster 81 and at home, in my shop I have a Thermal dynamics cutmaster 51. Never had an issue with either. The 51 is about $1400 from Cyberweld. Cuts 1/2" Does 3/8" easy. Tried to buy from LWS but price was to big a difference. Like about $300.00.
    Good luck
    Scott
    HMW [Heavy Metal welding]
    Jul 2007
    Batavia, NY
    159
    Quote Originally Posted by HMW View Post
    Good luck
    Those are great units HMW. I really like Thermals 1Torch. I like the consumable life and the fact that you can add extension cables to it if need be. The CM81 is a cutting mohambie. $1400 is a smoking good price for the CM51. Good purchase.
    Rich Ferguson
    Sales Technician
    Good luck
    I got the TD 38 and it cuts slower than I thought it would. I'd probably go with the 51 if I had to do it over again.
    951
    Yeah its a good price. I hate to not buy local but sometimes its big dollars difference. I buy all I can from LWS. Sorta like the Wal-mart thing I guess. Cyber weld probably buys thousands of plasma cutters. Funny though my LWS was real close on MIGs so we bought them from them.
    Scott
