Results 11 to 14 of 14
    Kamloops BC Canada
    82
    Default spoolmate 100
    I do not think changing the style of tip is going to solve the problem he is having just makes it cheaper to replace tips. I think it may be the end user that needs to adjust to the situation. diverdown
    2001 Dodge Ram welding truck. Hobart champion 10.000, miller Diversion 165. miller 180 autoset with spoolgun. SIP plasma cutter. Airless plastic welder.1996 28 foot bayliner for hauling dive and welding equipment
    San Diego, CA
    42
    Use about 3/4" of wire stick out. I too have burned a few tips using my spoolmate 100 on my Miller Passport plus, especially if you don't have much stick out. The wire speed has to be high, you need to move fast, pushing the gun along, I run around 20cf of argon. Also give the gun a rest after a few minuets of use, it over heats before you will ever hit the duty cycle of the welder power source.
    Jul 2008
    Waupun, WI.
    32
    Well as of right now I am not going to have any time until maybe Saturday to do any welding. I did get a container of nozzle dip and will try that along with turning up the wire speed. If I still have issues after a few hours of practice I will do the contact tip modification. I will also post a few pictures and see what everyone thinks. Once again for all the replys!!!
    Paul
    At home:
    Dynasty 200 DX
    Millermatic 211 Auto-set
    Spoolmate 100
    At work:
    2-Syncrowave 250
    2-maxstar 150
    millermatic 250X
    Dynasty 200 DX
    3,953
    Here are some pics of the mod. I am glad i did it and never would go back to a normal small tip...Bob
    1st pic. Remove barrel from gun then remove small screw and push out copper tube.
    2nd pic. Face off 1/16 or so from the end of the tube.
    3rd pic. Drill 7/32 or #3 if you have it. Drill about 9/16" deep. Chamfer the inside a little.
    4th pic Tap with a 1/4-28 tap and use a tailstock center for a guide.
    5th pic Done
