Results 1 to 10 of 15
    Feb 2009
    Manassas, Virginia
    7
    Default Robot, or a Robotic cart or wagon
    I have been looking around here for projects to try to find something that might help me out.
    I am in a wheelchair and have problems moving things from my van, to the back of my house which has a small hill to get around to my walk-in basement.
    I saw this in the recreation projects part here and got me to thinking.
    http://www.millerwelds.com/interests...ct/2780811531/
    I have been into R/C cars/trucks for a LONG time and don't think the electronics would be a lot of problems, but would like to get some ideas on what most think might do the job.
    I would like to have something that could carry a bit of weight, and that looked pretty beefy.
    Drop me a note here, or a private message if you can point me in the right direction.
    Thanks, Jeff
    Sep 2008
    southwestern ohio
    272
    If you go to www.machnebuilders.net they can probly help you be ase thee is guys over there that have built tractors and backhoes so the may be able to figur somthing out. I think some thing along the lines of aminiature forklift or wheel loader would work well.
    Oct 2008
    25
    Do you need it to be able to load and unload directly to your van or will you just be putting the items on the robot and you want it to help transport it to the back of your house?
    Feb 2009
    Manassas, Virginia
    7
    I will just be using it to move items from one place to another. I can get them out of the van, but there is yard, gravel and a slight hill between the front to back.
    I have to wheel the chair myself, so hard to pull or push anything, but could use a remote control radio to drive it and control it.
    I basically need something that is pretty fast in being able to just throw something on it, and get it from point A to point B.
    I have a tractor and such I cut grass and do other things, but it is in the shed, and once I am on it I don't have the use of my chair, so it needs to be something I can control by remote.
    Jeff
    Quote Originally Posted by dudical26 View Post
    Aug 2006
    Raymore Missouri
    1,925
    Maybe something like this?
    http://www.youtube.com/watch?v=JbHMVneIS5g
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Feb 2009
    Manassas, Virginia
    7
    The one on the U-Tube was very neat.
    Would be neat to find someone that was into the Battle-Bots, and had gotten out of it. Those parts they were, or are using to build them would be great for what I am wanting to do.
    Right now in the R/C world the big thing is Rock Crawlers. They do have the power, but just not big enough, and if you made them in larger form don't think they would have the power.
    Now people are seeing what I am wanting, something that I can put things on, sheet goods, dog food, anything I need to unload out of my van, and be able to take it around back. (it is he** getting old and being in a wheelchair too), but have come to the point in my life that I just don't have any help around the house and need to start on a build of something to help me out.
    I am sure that with all the people out here and their ideas I will come up with something.
    Keep the ideas coming.
    Jeff
    Dec 2008
    CDB Land, TN
    135
    Be safe
    Jeff
    Give more than you get and
    you will get more than ya need.
    This is true for the good and bad
    that life puts out.
    Feb 2009
    Manassas, Virginia
    7
    Some don't seem to understand what I am trying to do here.
    I am in a wheelchair, have been for the last 29 years. At one time I was a walking guy and you never think about things in a different way, but the chair really makes you have to think out of the box about how to do things.
    I have a John Deere tractor of which I have a Johnny Bucket on it, with a LOT of rear weight, so I can move around most things 450 pounds or so from one place to the other, but the tractor is in the shed, 400 or so foot away from where I am getting out of the van. I have to jump over to the tractor, then go and do what I am going to do, but I don't have the use of my chair and I can't get off the tractor to do anything then, and don't have any other help so have to be able to be in the chair at the same time.
    What I am wanting to build is a flat style transport of some kind, like I had in the first picture, where I can put sides on it, or tie something down, and be able to just put it at the back of the van, slide or get the stuff over to it, then use one of my remote controls to be able to drive it down to the back of my house and into my basement. (it is a walk out). Would only like it to be 3' or so at most wide to be able to get it around easier and get it through doors.
    Basically I am by myself, and don't have any other help, and have to be in the chair, being a T5 paraplegic, and wheel the chair aound by hand (not electric chair, makes one fat and lazy, and you can't build arms up pushing a joystick, hope I never have to get to that point) but need to make something that I can stay in the chair and move things around.
    Maybe that will give some more ideas.
    Jeff
    Dec 2008
    CDB Land, TN
    135
    Motors and gear motors
    http://www1.mscdirect.com/Gearmotors...002011257.HTML
    Wagon to work with
    http://www.globalindustrial.com/gcs/...FRKIxwodMm4-dQ
    Lift table
    http://www.chdist.com/material-handl...5093-8222-1061
    You did post you were gona build.
    I dont know if you are gona find a unit ready to go for your needs.
    Be safe
    Jeff
    that life puts out.
    Aug 2006
    Raymore Missouri
    1,925
    You say you want to build it. Do you have the skill and tools.
    How much weight will it have to carry? Does it need to be 4 wheel drive.This can be a costly project. R/C radio and receiver.....speed controller for best control but they can get expensive for large dc motors. There is a site that has lots of motors, switches, gearboxes etc called Surplus Center
    http://www.surpluscenter.com/ Making small r/c projects are easy because
    there are many resources but start getting big and it's another story. My r/c unit that I left the link for has two large dc motors but no speed controller. When I built this I checked into speed controllers for motors this size and it was over $500 by it self. It's a skid steer with my servos tripping
    micro switches that control power contactors. It's a mess of wires and switches but it was cheap and it's powerful. I had most parts. My parts are from a/c units,
    icemakers, go kart chains and sprockets etc. If you can get away with something lighter duty, maybe look for a childs battery powered car you
    can modify.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
