Results 1 to 10 of 11
    Mar 2009
    thomasville,NC
    6
    Default Miller Dialarc 250 DC stick welder,Rectifier Problem,Needing some info Please
    Hello,I have a Miller Dialarc 250 AC/DC stick welder,had some problems with it and found the problem with it,in Between the Rectifier above the Fan (3-Plates) the Brass contacts thats between the plates thats soildered are Burned up,i took apart to fix but have had No luck finding anyone with the parts?,would anyone have a supplier,or maybe the parts of one thats Bad?they just want to sell the entire Rectifier which is costly,I thought about just making the Brass contacts if couldnt get them,has anyone else done this.thanks for all the Posts here as they have been a Big help already,I hope to likewise be a help God Bless... eric from NC
    8,231
    Helpfull to know the age of the machine for that particular rectifier, If it's before a serial# starting with KF, that particular rectifier is not available, though the diodes are still available
    Dec 2008
    152
    You should be able to buy the diodes local fairly cheap.
    Cheers
    Mar 2009
    thomasville,NC
    6
    nothing is before the serial #,just the serial # KF974859,where would i get the Dioides?,also is the Dioides the brass contacts? or the round headed thing with 2 wires conecting the 2 plates,what burned up is the 2 prong brass contact that one of the main Bolts that hold the plates,the bolt goes through the Brass contact. if needed i could take a picture,
    Mar 2008
    Dallas,Tx
    172
    Default Dialarc
    Let's see a picture. We probably have what you need and the diodes are only about 20.00 if one is bad. PM anytime. weldersales
    Mar 2009
    thomasville,NC
    6
    Here is the brass contacts,one is good as in the picture but i have a few burned up.is this the Dioide?
    Mar 2009
    thomasville,NC
    6
    here is the Rectifier on another welder I have Both of the welders are the same as are the Rectifiers,i took this Rectifier off and put it on the welder thats bad and it started working just fine.
    8,231
    Thats a # 172504 rectifier, has to be replaced as an assembly, they cost anywhere from $221 to $334 US.
    Maybe weldersales has a used one...
    Mar 2009
    thomasville,NC
    6
    Yea your right,I called and talked to a welding place here and they said they only sale as one piece,I still believe if I cant find them I will try to make them,its a shame to junk the whole thing when everthing else seems to be fine.
    Dec 2008
    152
    The diodes are available, just have to be careful when dismantling and pressing the diodes back into the plates. You can buy cheaper rectifiers that would do just as good a job.
    Cheers
