Results 1 to 10 of 11
    Mar 2009
    Default Electrical plug adapter for Dynasty 200?
    I'm using a dynasty 200 which has a four-prong power plug with a central neutral pin in the middle of the four prongs. Just a twist and turn type plug.
    I'm looking for an adapter that will go to a standard 3-prong outlet (220). Just for a short bit of welding, so I'd rather not rewire another plug.
    Does anyone know where to find one of these?
    Sep 2002
    Clark County, NV
    2,696
    Center NEUTRAL?
    Maybe you should give us a part number, NEMA configuration, or at least a picture, because I think you are describing it wrongly or it has the wrong configuration installed.
    Is it a three-phase plug, or just has too many prongs?
    Either way, it'll probably have to be a homemade, or professionally made adapter, probably not something you'll find on the shelf.
    2,955
    I think you'll have to make one.
    Lake of the Ozarks MO
    3,594
    It did not come with a plug from the factory. Somebody else put that on there.
    I would chop that off and start over.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Oct 2008
    taxachussetts
    416
    this same thing was posted last month and i forgot to post pictures of my plugs. i'm going to take some now .i'll be back.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
    Oct 2008
    taxachussetts
    416
    I'm back. this is how i made my cables so i can hook up to 110 or 220. i used a 4 prong in case i need to hook up to a 3 phase. i can just make another short jumper. i hope this helps
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    miller 211
    evolution rage 2
    3,594
    Quote Originally Posted by vin-man welding View Post
    Almost exactly what I went to
    Miller WC-115-A
    Miller Spectrum 300
    Jan 2009
    Cleveland, TN
    229
    I was going to do that, but should never need 3 phase. So, did the 10/3. The manual says you get a higher duty cycle on single phase if you go to 10 awg.
    Dynasty 200 DX runner
    Sync 350 LX
    XMT 300 w/D74 and roughnecks
    Hobart 135
    ESAB PowerCut 875 plasma
    Sep 2002
    Clark County, NV
    2,696
    If adapting from a 3-phase plug to a single-phase plug, you'll need to know which prong you tied the red wire to so you do not carry that one through the adapter.
    Other than that, keep the green on ground, and you pretty much can't screw it up.
    3,594
    Quote Originally Posted by MAC702 View Post
    Exactly...but remembering () I just make it (red) the opposite one and even then if a little unsure just crack it back open and look. Better safe than sorry
    So far every time I have needed or wanted to use three phase the client had some plug configuration that nobody stocked and I ended up doing something different.
    Miller WC-115-A
    Miller Spectrum 300
