Results 11 to 20 of 31
Thread: New But Not
    Aug 2007
    arkansas
    781
    thanks for the compliments on the bridge, it was alot of fun. the upper and lower frame is made of 3x3 .125 wall square and the "webbing" is of 2x2 1/4 wall square. the deck cross members are made of 3/8 structural square zee bar 3x3. i also forgot to mention that i also have a synchrowave 200. it is dedicated to tig on aluminum, though. as for the question"what is an arc one inverter?" it is a 110 volt cc machine made by arc one. smaller than the maxstar by miller and not as good either but 6 to 7 hundred bucks cheaper. i needed a "backpacker machine" to weld some "big *** fans" to girders in a building. see pics below. it is a 24 foot ceiling fan and the 1/0 leads from my legend were too much to handle 45 foot up on an extension ladder. the inverter weighs like 7 to 10 pounds comes with a shoulder strap and will weld 100 amps at 60%. i had to weld up a support frame to the girders to hold up the fans.the fan company is called "big as s fans" check them out at bigassfans.com
    welder_one
    www.sicfabrications.com
    Aug 2007
    arkansas
    781
    here are some pics of my hot water tank grill
    welder_one
    Aug 2007
    arkansas
    781
    here is a pic of my old rig truck next to a hitachi ex 1100 shovel. this was in the rock quarries. i had to hard face the bucket. took me about 48 or so hours.
    welder_one
  4. #14
    Aug 2007
    arkansas
    781
    Quote Originally Posted by BWS29128 View Post
    I love Miller's 304 welders, but my Champion 10,000 won't power it and the money for a wire-feed system (as opposed to a spool gun) just isn't in my cards at the moment...
    ~Clint
    I really like the 304 as well but i wish i had gotten the next one bigger. the arc characteristics on stick are awesome, but when i get to the big aluminum stuff it really starts to lag behind with duty cycle and all.
    welder_one
  5. #15
    Dec 2006
    Wartburg,Tn
    575
    Welcome aboard! those are some nice projects
    Inferno Forge
    Chris
  6. #16
    Jun 2007
    Camden, SC
    156
    that is one SERIOUSLY bigazzshovel!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Holy Shiite Muslim, Batman!!!!!!!!!!!!!!!!!!
    The fan website is really kewl...never seen anything quite like that before.
    Do you have a website for ArcOne? Nothing I'm trying is coming up on Google. I'd like to see their stuff.
    I still think I'll end up wth either a MM210 or a MM212 with spool gun by Monday afternoon. Probably an HTP version of the 3035, but I've been wanting to buy something from them for over two years. One of these days I'm GOING to shell out the $3000 for their Invertig201 AC/DC!
    Clint Baxley
    Baxley Welding Service
    Rembert, SC 29128
  7. #17
    Jun 2007
    Camden, SC
    156
    Never mind..........after all of that, I accidentally joined the two words and found them by accident!
    http://www.arc1weldsafe.com/weldingmachines.htm
    Clint Baxley
    Rembert, SC 29128
  8. #18
    Aug 2007
    arkansas
    781
    that is funny, my local weld supply carried the arc one inverter. now they will try to sell the maxstar. a friend used to work there and he demo'ed the machine to me and said it would burn 1/8 7018 rods. if it don't bring it back. i took it home and tried it out. plugged it in to 110 power and i burned about 2 pounds of 1/8 7018 before i gave up on trying to make it cycle out. it is a little hard to start the arc though. it wont run 3/32 6010, but will run 3/32 6011, not 1/8 6011. arc1 said that it will scratch start tig, so i tried. let me tell you now, dont waste your time. it is a very good stick machine though.
    welder_one
  9. #19
    Aug 2007
    arkansas
    781
    here are a couple more pics of some projects: an aluminum dust pan (boredom) and a 2 legged bar stool out of aluminum. i thought my shop at home needed a little more stuff crammed in somehow.lol ooh, i almost forgot... also a pic of an aluminum parts washer/ solvent tank. (i have access to a lot of "scrap" aluminum)
    welder_one
  10. #20
    Aug 2007
    arkansas
    781
    one more of the bar stool
    welder_one
