Results 1 to 1 of 1
    Feb 2009
    Salt Lake City UT
    21
    Default Glad I brought my welder in
    Hello All,
    Friday I came in to work to find that the Night shift techs had lifted the product conveyor belt and put it on a stack of blocks to raise it up.
    These blocks where in the center of the cross member,and the belt was wobbly. Good thing I brought my welder in. I welded the blocks together so that they could be used under the wheels. (see first pict). Filler was 3/32" 70-S2 @ 70 amps.
    Then I looked at the light shield made of cardboard and Duct tape. I took a few measurements and cut and welded one from some scrap SS. (see second pict), Filller 3/32" 308L . Still need to drill and mount to the end of the machine.
    Miller Dynasty 200 DX
    Miller Spectrum 375 X-TREME
